Thread: Rear Main Seal Catastrophic Failure - Rebuilding Engine
Results 1 to 14 of 14
  1. #1 Re: Rear Main Seal Catastrophic Failure - Rebuilding Engine
    Apr 2014
    Maplewood
    Another question -
    If I wanted to just replace the RMS and the crankshaft... Can this be done from underneath the car, or would the whole engine have to be pulled? Has anyone attempted this?
    Thanks in advance
  2. #2 Re: Rear Main Seal Catastrophic Failure - Rebuilding Engine
    HUDSON
    Quote Originally Posted by CNorell145 View Post
    Another question -
    If I wanted to just replace the RMS and the crankshaft... Can this be done from underneath the car, our would the whole engine have to be pulled? Has anyone attempted this?
    Thanks in advance
    Chances are that if the engine was starved for oil, the crankshaft will not be the ONLY damage, which means the entire engine assembly needs to be disassembled, and inspected, and worn parts be replaced, but rebuilding an engine is not just replacing parts, it involves enough to write an entire book, so, if your not experienced at rebuilding engines, don't do it.
  1. Rear Main Seal Opinion
    By 50Coupe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2014, 10:24 PM
  2. Do i need to remove crankshaft to replace rear main seal
    By GTPlzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2013, 11:00 AM
  3. Rear main seal
    By FX4 Level II in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2012, 02:03 PM
  4. Rear Main Seal Plate
    By NHRA21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2011, 05:49 PM
  5. Main engine bearing failure
    By 03grandprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2011, 08:50 PM
