Thread: 3800 Big Bore
Results 1 to 16 of 16
  1. #1 3800 Big Bore
    Apr 2014
    Maplewood
    Has anyone attempted or successfully pulled off doing a .020" or .030" big bore on their 3800 engine?
    If so, what was your approximate horsepower gain, and what pistons did you use?
  2. #2 Re: 3800 Big Bore
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    I think there's been a few and it ends up being like a 4.2L or something, not really sure on the horse power or anything like that though. Just look it up on google, there used to be someone who had a kit put together for it I think, that or it was like a stroker kit or something.
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  3. #3 Re: 3800 Big Bore
    Oct 2013
    MARYLAND
    Here's a link t someone who was successful with it, but it's from back in 2009.
    http://www.thechicagogarage.com/foru...2-stroker.html
    -Thomas Fuller-
  4. #4 3800 Big Bore
    After the time, money and gains etc wouldn't be worth it. There's others things that will do more for you and cost you less.
    04 Comp G.
  5. #5 Re: 3800 Big Bore
    Feb 2013
    37.295091, -121.930053
    red winter is over i dont think he wants a coat
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  6. #6 Re: 3800 Big Bore
    Damn autocorrect
    04 Comp G.
  7. #7 Re: 3800 Big Bore
    Feb 2013
    was thinking thats what happen so i wasnt trying to be to hard on ya cuz that does happen to everyone
  8. #8 Re: 3800 Big Bore
    Antioch, IL
    Come on now 3.8 is gay, 4.2 is where its at.
    2009 Challenger SRT8
    Expert at being gay.
  9. #9 Re: 3800 Big Bore
    Apr 2014
    Maplewood
    MCbatt - thanks for the link
    ITHURTZ - no replacement for displacement eh? haha
  10. #10 Re: 3800 Big Bore
    May 2013
    illinois
    for the money i would turbo the stock motor and make twice as much power
  11. #11 Re: 3800 Big Bore
    St. Louis
    To do something crazy you could grab a vortec 4.3L, throw in a 4T80 trans and then turbo it. Might need an adapter plate for the trans. Would be different for sure.
  12. #12 Re: 3800 Big Bore
    Apr 2014
    Maplewood
    Well to do the work myself, the parts and machine work would only cost $1500 or so, and I believe a turbo costs around $3000 or so? Correct me if I'm wrong.
    Overall, I wouldn't mind having a turbo on there - more immediate power is always nice, rather than building up the supercharger.
  13. #13 Re: 3800 Big Bore
    Feb 2009
    flintnasty MI
    Labor and money going into a stroker build would be more expensive than a turbo.
  14. #14 Re: 3800 Big Bore
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    I would have went with a 4.2 stroker but the only companies I found that offered them were in Australia and they wanted way too much for them
  15. #15 Re: 3800 Big Bore
    hangover park IL
    20 overbore gives you what like 2 extra cubes at most.
    the stroker kits are not worth it unless you have a SI tall deck motor.
    the SII already has horrible rod/stroke ratio from stock....why make things so much worse.
    a tiny turbo on a bone stock 3800 will break most transaxles.
    ~James~ Psychotic Gearhead
  16. #16 Re: 3800 Big Bore
    Apr 2011
    Vassar, Mi
    My motor is .020 over, made the holes round again and gave me a nice fresh cylinder wall finish. Speedpro/Sealed Power hypereutectic pistons with ceramic coating. As stated above over bore of .020 - .030 gives such a negligible difference in displacement you would never realize any measurable gains in output. A C.O.M.E 4.2L stroker kit with a completely custom rotating assembly might. However at $3k for rotating alone not including machine work, valve train, heads, assembly labor, big blower or anything and everything else needed to utilize the setup. A turbo is a much smarter option
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  1. Hub Center Bore?
    By Mr D in forum Tires & Wheels
    Last Post: 11-02-2012, 10:19 AM
  2. Brake Bore Inlet Size
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 05-01-2011, 10:46 AM
  3. bore an LS4?
    By jlt695 in forum 5.3L V8 (LS4)
    Last Post: 01-26-2011, 01:05 PM
  4. bore an ls4?
    Last Post: 01-26-2011, 10:29 AM
  5. Whats our hub bore size?
    By Agentlongwood in forum Tires & Wheels
    Last Post: 01-18-2010, 01:23 AM
