Thread: White grit in engine bay????
Results 1 to 6 of 6
  1. #1 White grit in engine bay????
    SE Level Member Thethudelh's Avatar
    Apr 2014
    Sandy Ridge,NC
    I was wondering if anyone could steer me in the right direction with this. I have a 2000 gtp that is stock. I have a leak in the oil pan gasket a coolant leak from what i believe is the intake gasket and i know i have a slow refrigerant leak. Now my issue...i have a white gritty residue on my strut tower brace and around the altenator but nothingju as i can see on the nose cone of the s/c. Its also on the coolant resevoir. Since it had been a bad winter i assumed it to be salt from the road so i just cleaned it off. But now im sure thats what it aint. Any help is greatly appreciated. Thank you.
  2. #2 Re: White grit in engine bay????
    sounds like metal shavings, pick some off with your fingers see if its gritty, if so pull your belts and check your pulleys.
  3. #3 Re: White grit in engine bay????
    Apr 2014
    Sandy Ridge,NC
    Thank you. I was able to check the s/c belt pulleys and they looked fine. I think it may possibly be from the waterpump. I also found a bit of coolant on top of it. Ill have to dig in further later on.
  4. #4 Re: White grit in engine bay????
    coolant could be the upper elbow leaking.
    the a/c compressor clutch likes to put out metal savings too, so look down by it. belt off, spin the ring the belt rides on. if it sounds like metal on metal thats your issue.
    you can also use a magnet to see if the chips stick to it. if so its metal for sure.
  5. #5 Re: White grit in engine bay????
    hangover park IL
    the belt spins clockwise and loves to carry saltwater/debris from down near the cradle and shoot it up towards the alternator.
    its road salt
    ~James~ Psychotic Gearhead
  6. #6 Re: White grit in engine bay????
    Apr 2014
    Sandy Ridge,NC
    I think i finally got it fixed. Will find out in a couple weeks
    2000 GTP....need mods...so far only GMPP suspension and flipped dogbone mounts.
  1. l67 engine wont stay running..got the car running. tons of white smoke from exhast
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 05:14 PM
  2. 3800 supercharged engine white smoke
    By boostman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2011, 10:04 AM
  3. white 02
    By whiteponti2002 in forum Introductions/Noob Questions
    Last Post: 11-15-2010, 10:08 PM
