Thread: fob serial #....how to turn off the alarm without fob?
Results 1 to 7 of 7
  1. #1 fob serial #....how to turn off the alarm without fob?
    SE Level Member 97grandprix1's Avatar
    Apr 2014
    Post Falls Idaho
    My searches didn't yield anything useful so i'll keep it simple. Does anyone have a link to the acceptable fob numbers for a 97gtp? the 1 that came with the car doesn't work and I'm not sure of how to shut off the alarm if it goes off in the grocery parking lot. our 08 Yukon has a chime when u power lock the doors and shut them, 10 sec later the doors actually lock and the alarm sets. same here. I've been leaving it unlocked and storing stuff in the truck as a hope not measure/may be interested if someone has 1 left after the sale of a car
    97 GTP / new head gaskets / plugs and wires / 180 stat / U delete / 3" cat back to v-force / rebuilt S/T / cone filter......Family car, we're not station wagon people
  2. #2 Re: fob serial #....how to turn off the alarm without fob?
    it wont go off unless you can turn it on, clearly the fob dont work, so lock your doors, and use the key to get back in.
    then buy new fobs off ebay.
  3. #3 Re: fob serial #....how to turn off the alarm without fob?
    Oct 2011
    Toledo, OH
    Also, a possible problem with the fob is the battery terminal broke off the circuit board inside. This happens when the battery in the fob starts to die and idiots smash the crap out of the buttons when the car won't unlock. Pop it open, resolder the battery holder, get new battery.
    7"
  4. #4 Re: fob serial #....how to turn off the alarm without fob?
    Apr 2014
    Post Falls Idaho
    so simple I must have wasted a thread THX!
  5. #5 Re: fob serial #....how to turn off the alarm without fob?
    Apr 2014
    Post Falls Idaho
  6. #6 Re: fob serial #....how to turn off the alarm without fob?
    Yoga city
    don't get me wrong, but does you 97 even have the alarm option? I know it normally has the AU0 cod for fob. I would double check your RPO code sir
  7. #7 Re: fob serial #....how to turn off the alarm without fob?
    Apr 2014
    Post Falls Idaho
    ya its an alarm car, and it turns out the fob I have is off e-bay and hasn't been programmed yet, what might be the key words for that sticky, the search forum tool and I are still getting acquainted.... I know I saw it somewhere
  1. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  2. Alarm going off inside car when reaching highway speeds..coolant temp alarm?
    By MattTheBaker123 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2012, 09:39 AM
  3. Adding VIN and Serial to Bin?
    By Pure2sin in forum PCM Tuning
    Last Post: 01-18-2012, 02:01 PM
  4. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
