Re: cranks no start
Looks like you are using an aftermarket gearset. There's a few things things to keep track of
Balancer and cam balancer gear must line up their dots.
Then, turn the cam so the key is approx 4-5 oclock
Turn crank so key is approx 2 oclock
If there's a dot or 0 on the key hole of the crank gear, put it on they keyway.
Now the 0 or dot on the tooth of the crank gear should be pointing to 12 oclock
Line up the cam gear dot/keyway and you should be able to take pics of all dots/0's lining up.
And put your old crank gear back on with the new one on. All dots should line up. This is your triple check that everything is correct.
http://i20.photobucket.com/albums/b2...c/IMG_1637.jpg
http://i20.photobucket.com/albums/b2...c/IMG_1636.jpg
http://i20.photobucket.com/albums/b2...c/IMG_1635.jpg
Re: cranks no start
right now its sitting just the way yours is pictured and yes its a rollmaster singe
Re: cranks no start
Now you check compression.
Re: cranks no start
compression still off... but the car ran for a second.. but the flex plate is messing up.. so im snatching it back out... putting new valves in it...and changing flex plate..
Re: cranks no start
Smooth the tops of the pistons where the valves hit while you are at it.
Re: cranks no start
