Just quick Q, If the water pump is missing a bolt will coolant come out of that port? I have a huge coolant leak. I thought it was a bad hose or even the water pump. But, further into it I saw last night wile putting water through the radiator, water was coming out on the right side of the water pump, like you turned the faucet on 1/4 of the way. I cut a hanger and tried to feel any threads t see if there was a bolt that had to go in there, or even a freeze plug.
Any suggestions.
