Thread: Starting issue.
Results 1 to 11 of 11
  1. #1 Starting issue.
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    So every once in a while car won't start. Has power. Radio everything turns on. Starter doesn't click. After a while it usually starts. Ground maybe?
    2001 sliver gtp her name is Reagan
  2. #2 Re: Starting issue.
    check the tranny grounds, and the starter wires, and the battery terminals.
  3. #3 Re: Starting issue.
    Oct 2012
    Fort Wayne, Indiana
    Okay. Currently in a walmart parking lot. Lol
  4. #4 Re: Starting issue.
    see if the battery connections move, a little twist of the hand can help a ton if they are loose.
    wiggle the grounds.
    then theres the good old beat on the starter trick. maybe its dead and needs a beating to jump back to life.
  5. #5 Re: Starting issue.
    Oct 2012
    Fort Wayne, Indiana
    Do I crank it while I hit it. Or can I just hit it cause it's just me by myself lol
  6. #6 Re: Starting issue.
    you can hit it 3 or 4 times rather hard, then go turn the key. if you dont have a hammer think large rock or brick.
  7. #7 Re: Starting issue.
    Oct 2012
    Fort Wayne, Indiana
    I used a adjustable wrench. Didn't work
  8. #8 Re: Starting issue.
    also make sure the tranny shiftier is in park. the plastic cable ends like to break or wear.
  9. #9 Re: Starting issue.
    some times it needs a good hard hit. if the wires are all tight and clean looking.
    if you got a screw driver handy try jumping the starter motor. do this with the key to run. that way if it cranks it can start.
    if that dont work try smacking the key side of the column.
  10. #10 Re: Starting issue.
    My 98 used to do this but only once in a great while
  11. #11 Re: Starting issue.
    Oct 2012
    Fort Wayne, Indiana
    I fixed it. Ground wire to starter actually broke
  1. New guy with a starting issue
    By dmj in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-17-2014, 09:20 PM
  2. Starting issue
    By Zach Chapman in forum General Grand Prix Discussion
    Last Post: 12-25-2012, 10:11 AM
  3. Please someone help me out here, starting issue.
    By Brickie in forum General Tech Discussion
    Last Post: 01-12-2012, 12:10 AM
  4. Please someone help me out here, starting issue.
    By Brickie in forum Off Topic Discussion
    Last Post: 01-09-2012, 12:30 PM
  5. Starting issue
    By GTP Ryan in forum General Tech Discussion
    Last Post: 08-28-2011, 02:55 AM
