Thread: Oil Leak
Results 1 to 11 of 11
  1. #1 Oil Leak
    Aug 2012
    South Carolina
    My 1998 Grand Prix GTP is leaking oil. I have to add a little under a gallon of oil a week. I've been under the car to try to find where the the leak is and the only place I can see oil coming is a joint in a silver colored line that takes a back & forth path underneath the engine. The oil leaking from this joint is fresh engine oil so I'm pretty certain this is the problem.
    Can someone tell me what this line is and how easy it is to replace?
    Thanks
  2. #2 Re: Oil Leak
    sounds like a oil cooler line, see if you have 4 lines into your rad, 2 on each side, or follow the lines. if not to the rad to a external oil cooler.
    posting a pic would help a ton too.
  3. #3 Re: Oil Leak
    Need picture.
  4. #4 Re: Oil Leak
    Aug 2012
    South Carolina
    Need picture.
    Thanks - Yes there are 4 lines going into the radiator, as well as the two hoses. Will get picture when I have the car up on stands again tomorrow.
  5. #5 Re: Oil Leak
    sounds like you need a new line, or repair the break in this one. you can use a compression fitting to re joint the pipe.
  6. #6 Re: Oil Leak
    hangover park IL
    How do you have the 9c1 engine oil cooler on a 98 gtp...
    most large engine oil weeks can be traced to the rear main engine cover or to the oil pressure sending unit above the power steering cooler near your passenger axle with the bright green connector unplug it and a good amount of oil should pour out and be wet on the inside from where it's leaking internally to the wire terminals.
    ~James~ Psychotic Gearhead
  7. #7 Re: Oil Leak
    believe it or not it was a option. not seen often, but there was another member who had it stock. and it was in the rad, dual coolers.
  8. #8 Re: Oil Leak
    Aug 2012
    South Carolina
    Update - Leak fixed. It was the oil pressure switch. Replaced that and the problem is solved . Sorry I didn't get the pictures up - Bad weather prevented me from getting under the car again. Thank you all for your input.
  9. #9 Re: Oil Leak
    91C wasn't a seperate external cooler? According to the GM stuff I had found, it was external.
    http://www.grandprixforums.net/threa...ghlight=police
  10. #10 Re: Oil Leak
    hangover park IL
    that would have to be a G/H body
    and only the earlier ones had the engine oil cooler inside the radiator end tank on the drivers side, though ive seen a few later cars with them installed because of the larger radiators in the early cars.
  11. #11 Re: Oil Leak
    we've seen them on the site here, factory external coolers, oil and trans. (97-03 only) its rare tho. like you had to order with those options new.
    i questioned it so hard myself i asked the guy to post pics of the dual lines in the rad tanks, tranny one side, oil on the other. it was all there like he was claiming.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
