Thread: Your not so typical misfires?
Results 1 to 20 of 31
  1. #1 Your not so typical misfires?
    gardner,mass
    Ok so awhile back i noticed i started getting these random misfires showing on my torque app so i started with replacing parts in hopes to solve this issue.
    Parts replaced include:
    al 104s (gapped .055)
    delphi wires
    icm from a low mileage impalla at jy
    maf
    ac delco fuel filter
    vac lines
    sea foam
    02 sensors
    Still seeing these misfires
    I checked for any exhaust leaks or vac leaks and nothing.
    I also testing my fuel pressure and pressure was a little low befor replacing the fuel filter but after that was fine but i am unable to test while driving because my hose with my gauge wasnt long enough but im seeing the misfires at idle anyway so it shouldnt matter.
    I took the car to get tuned my Snowflake and when i did he noticed i was running pig rich and my injectors were going static so he tuned the car and it was running better than ever. He also showed no signs of misfire on his dhp so i thought it was just my torque app sucking. This tune was done without a wideband at the time and befor i threw on the 3.6.
    Well shortly after I had a check engine light. One code was due to not having an egr and he forgot to get rid of it when he tuned it but then another i had a misfire on cyl 4.
    Ive been really busy and having really had a chance to look into the car. Until today i finally got my aeroforce working cus of a bad cable. Well i looked at my dtcs and noticed i now have a p0300 instead of a p0304. So i scanned for misfires and am getting random misfires across all cylinders.
    So i went for a run scanning for knock watching my wideband and also my timing.
    At wot im seeing around 12.5-13 on the wideband. around 11-14 on the timing and i start to knock (1-3.5) when the wideband goes under 13
    So im lost on this. Yea the car need to be retuned with the 3.6 and wideband but im thinking there is another underlying issue. Maby my fuel pump is bad and hense the reason my injectors were going static? But then again i wouldnt see misfires at idle when my fuel pressure is reading fine.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Your not so typical misfires?
    What's your fuel pressure at?
    04 Comp G.
  3. #3 Re: Your not so typical misfires?
    gardner,mass
    I know it was where its supposed to be on an 04 car. Somewhere around 60-64 i think. Ill go outside and check right now for the hell of it.
    Quote Originally Posted by Below Average Joe View Post
    lim gaskets ever been changed?
    ofc
    Edit:yup reading 59 psi right now
  4. #4 Re: Your not so typical misfires?
    Aug 2011
    'Merica
  5. #5 Re: Your not so typical misfires?
    Aug 2011
    'Merica
    ofc?
  6. #6 Re: Your not so typical misfires?
    gardner,mass
    ofc?
    Ofcourse
  7. #7 Re: Your not so typical misfires?
    Aug 2011
    'Merica
    i'm interwebz illiterate.....
  8. #8 Re: Your not so typical misfires?
    gardner,mass
    So i was thinking about all probable causes for a misfire and something dawned on me. When i got the car i did replace the lim gaskets but when i did i was without a vehicle and had no way of getting anywhere. Well after i tore everything apart i forgot the lock tight. So i just cleaned up the bolts and torqed them down. Is it possible that maby the bolts came lose and i have an intake leak causing all my issues? I guess i could go recheck the torque but at the same time wouldnt this show up scanning my vacuum cus im reading good at anywhere from 20-22.
  9. #9 Re: Your not so typical misfires?
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    misfires ergo firing. After all you have done ck cam and crank sensors and coils.
  10. #10 Re: Your not so typical misfires?
    gardner,mass
    Quote Originally Posted by lewis1952 View Post
    When i swapped the icm i grabbed the 3 coils aswell and no difference with them not to mention i dont think all 3 coils would be bad.
    Ima do a case relearn with my aeroforce for ****s and giggles. I just dont feel like replacing the cam and crank sensor for no reason.
    Edit: Have i mentioned how much my car sucks ass? Just scanned my codes again and p0136 (bank 1 sensor 2) But i replaced it less than a year ago with a denso. Maby cus my car was running so rich it ****ed them up?
    Or maby its because i had to extend that harness when i installed my headers and where i soldered in the extention its corroded. I used shrink wrap and then wrapped it with electrical tape though. This car is driving me nuts.
  11. #11 Re: Your not so typical misfires?
    59 psi lmao damn
    04 Comp G.
  12. #12 Re: Your not so typical misfires?
    gardner,mass
    59 psi lmao damn
    i dont get it?
  13. #13 Re: Your not so typical misfires?
    My pump is dying so I get nowhere near 59 psi.
    04 Comp G.
  14. #14 Re: Your not so typical misfires?
    gardner,mass
    Oh ic, Hey btw you said on another forum that you had no problems doing a case relearn with your aeroforce? Im having the same thing the other guy was. I start it and it tells me to press in ebrake and release so i do then it says to rev to 4-5k. My car rev limits while in park at like 3.8. then it tells me to shut off and restart in 30 seconds. But when it says to rev it says wait till the pump turns off? but it doesnt it just goes to the next screen.
  15. #15 Re: Your not so typical misfires?
    Weird mine did it just fine the first time around but after that I just do it this way...dare i say do it the old fashion way
    No case learn is needed if you don't get a check engine light.
    For 2004 Grand Prix only:
    Set the parking brake to disable the daytime running lights system to avoid draining the vehicles battery.
    Try to start the vehicle by turning key to the START position (using a Master Pass-Key key, not a Valet key).
    Observe the SECURITY telltale on the driver information center. Allow the key to fall back into the ON position. DO NOT TURN THE KEY TO THE OFF POSITION.
    After no less than fifteen minutes turn OFF the ignition and wait for ten seconds.
    Start the vehicle.
    04 Comp G.
  16. #16 Re: Your not so typical misfires?
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Ginseng View Post
    delphi wires
    maf
    vac lines
    sea foam
    02 sensors
    I am almost perfectly convinced this is a troll post.... It has to be.... this Nick kid CANT POSSIBLY be this utterly stupid.
    Anyway, snowflake obviously went through some effort to bait you into saying this so ill bite.
    Bull****. Snowflake is a hack, and has no idea what he is doing. Your injectors were not "going static", he had the wrong IPW reading on whatever he was scanning your car with. A stock or even a bench tuned PCM is not able to send the injectors static with max fuel trims. The wrong IPW readout is common and I dont think even HPT reports them correctly.
    Makes yah wonder what else he was "forgetting" eh?
    I assume you are running 93? If so this is INSANE lean. Like, if I wandered too close to high 11s i was afraid on my old 93 octane days.... you NEED fuel when running 93 on an edge tuned setup like this.
    The only time you will "stress" a fuel pump to lean a car out, is in PE, which at that time the PCM does not collect data from the o2 sensor. A bad fuel pump will never be able to be compensated for so you can rule that out.
    misfire on cyl 4.
    From any car I have seen running 13afr's and a smaller pulley, this means chipped piston, every time. Time to pull the plugs and see the carnage.
  17. #17 Re: Your not so typical misfires?
    Banned
    CT
    DH you've been going out of your way a lot to smear me lately.
    I opened up OP's bin file to see what I changed.
    AFR is leaned out 6 tenths, nothing else was changed with the fueling.
    I remember telling him that I don't make it a habit of playing with fueling without a wideband.
    I do know that the stock tunes come pretty rich, so 6 tenths wasn't something I was too concerned about.
    I told OP we should retune it ASAP with his smaller pulley (especially it being GenV) on the wideband.
    That was back in September.
    I'd be more than happy to give you a retune and check the car out to see if we can find the source of the misfires, for free, even though it's been 7 months since I've touched the car.
    Hopefully you've got no damage.
    edit: just looked at the logs.
    We were commanding AFR in the mid 11s, fuel trims were tight, and we pulled to over 100mph back to back with no knock.
  18. #18 Re: Your not so typical misfires?
    Feb 2009
    flintnasty MI
    You dont like playing with fuel, but you pulled out 5% of the fuel in PE? With a car that might be trimmed on the side of lean already? Kidding me?
    How does one "not make injectors max out" with just a 5% change anyway? You'll get maxxed out readings at well less than 80% IDC if you are using the wrong formula for IFR and a 3.6 pulley setup should go north of that by quite a bit. Again this is extremely common knowlege for anyone that has ever tuned any 3800 before... are you saying this was your first tuning project? And if so you took a bold move removing fuel?
    Considering commanded AFR is DISPLAYED TO YOU through a PID you can find out exactly what they come, and ill tell you right now that the tip in AFR isnt 11s, or 10s... its in the 12s. Not my, the internet, or even bad tuners idea of "rich".
    Smear? How about damage control. You are wrecking innocent peoples cars for YOUR OWN ENTERTAINMENT. I am so sorry you think that I am trying to 'smear' (aka falsely accuse) you of this when its so obviously true.
  19. #19 Re: Your not so typical misfires?
    Banned
    CT
    I've had dozens of stock tuned cars on the dyno AFR is always in the 10s.
    Show me a stock tuned near stock car with AFR in the 12s at WOT.
    You're out of your mind as usual.
    according to the logs, when the OP left his IPW's were 21-22ms according to DHP
    Whether that's accurate or not is kind of irrelevant since fueling was barely touched and the car ran great with no knock.
    Just for clarification, his pulley swap was done after I tuned the car.
  20. #20 Re: Your not so typical misfires?
    Enfield, CT
    try cleaning the ICM contact points. Seems to help alot everywhere I worked in Assachusetts
  1. Typical Gxp trans leak
    By jteske88 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-10-2012, 11:55 AM
  2. Typical gas mileage for 1999 GP?
    By Z28 in forum General Tech Discussion
    Last Post: 04-22-2010, 05:06 PM
  3. Typical...
    By blueguy in forum Tires & Wheels
    Last Post: 02-10-2010, 04:27 PM
