Thread: Shocks
Results 1 to 15 of 15
  1. #1 Shocks
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Anyone know what the difference in shocks from 99+ are? I have a 99 GTP and need some rear suspension pieces. The back end drops considerably just by the weight of fuel. Wondering what year suspensions will fit my '99
    Sent from my SM-N900P using Tapatalk
  2. #2 Re: Shocks
    97-03 struts are the same.
    I bet your rear springs have become really weak, but at that point I'd replace both.
  3. #3 Re: Shocks
    Aug 2011
    Michigan
    Alrighty. Thank you
  4. #4 Re: Shocks
    Aug 2011
    Michigan
    So 04+ won't work on the older model, right?
  5. #5 Re: Shocks
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    you can get plug and plays off ebay for $122 free shipping
  6. #6 Re: Shocks
    hangover park IL
    you can use the 04-08/09 struts to work but keep in mind the spring rates changed over the years/models
    I have 04+ CompG rear struts with 04 CompG front springs on em on the rear of an 00 regal drag car
    ~James~ Psychotic Gearhead
  7. #7 Re: Shocks
    Aug 2011
    Michigan
    So if you used the 04-08/09 model struts along with the same year springs you should be fine? Since then the spring rates would match the struts?
  8. #8 Re: Shocks
    hangover park IL
    the spring rate depends on the weight of the back half of the car, not the shock.
    so if you got rear springs for a 9c1-3 impala your ass end might sit 1.25" taller than your stockers did when brand new
    the strut you can use no problem, dampening isn't what your complaining about, its height. which is the springs,
    your looking for rear springs for a vehicle with your F/R weight bias and overall curb weight. just be aware that the different models will sit differently. the buick springs tended to be soft, etc, etc
  9. #9 Re: Shocks
    Aug 2011
    Michigan
    I see. So the springs for the 04+ GP's I assume would probably make the back end sit higher than the stock springs for the 97 - 03 GTP's?
  10. #10 Re: Shocks
    hangover park IL
    take each car and put it on a scale for full curb weight, then measure just the rear weight, if the numbers are close to the same for both then id say your right.
    if not then you may end up lowering it instead of raising it....
    id personally guess they are close since curb weight on both is fairly close and id figure the fold down rear seat and changes in body cladding is likely the same weight and not less weight...
    what id suggest is spending some time looking up part numbers /weights from various years and models or just guess lol
    what im saying is its a complete crapshoot unless you do a good bit of research
    but yes the parts can swap
  11. #11 Re: Shocks
    Aug 2011
    Michigan
    Alrighty. I gotchya. Thank you for the information. I'll look into it a bit more. I just have seen a few people selling the suspension from their Comp G's and 05 GP and what not and I was wondering if it would fit my 99GTP. I l'll see what I find out though =P
  12. #12 Re: Shocks
    hangover park IL
    oh I know the cG's got stiffer valved struts and they all had dual exhaust so the chance that a set of those have close tot he same spring rate. with the same mileage or less than yours would probably do what you want but I dunno that you gain maybe a 1/4" height....but if they are from a 60k car and your has 150k then id guess closer to .5+"
    that's all im saying if your car hauled lots of weight for most of its life youll see more of a rise...if your cars only had 1 person in it its whole life then id doubt the springs are that sagged that youd see much difference.
    so factor everything in
  13. #13 Re: Shocks
    Aug 2011
    Michigan
    My car has about 194k on it, and Idk if the suspension was ever replaced. But I can tell you that the hitch someone had put on will hit sometimes pulling out of places if I have 2 or 3 people in the back seat. And with nobody in the back seat you can see the back drop about 2 inches give or take when filling the tank from near empty
  14. #14 Re: Shocks
    hangover park IL
    well hell even 100k 97-03 springs would jack you up a bit.
    a hitch is sorta a dead giveaway that the springs may be pretty sagged.
    also don't forget that a fuel fillup is like shoving a passenger in the back seat usually around 120lbs or so
    id find those Cg struts n run with em, probably what ya need.
  15. #15 Re: Shocks
    Aug 2011
    Michigan
    Thats whaylt I'm thinking. I figured the Comp G ones might be just what I need. I'll see if any are available
  1. Will shocks/springs off my 07, fit on 97-03's?
    By poopoopeepee in forum Brakes/Suspension/Chassis
    Last Post: 06-23-2013, 06:17 AM
  2. I need a set of rear shocks
    By TEK310 in forum Southwest
    Last Post: 06-10-2013, 09:02 PM
  3. What Shocks & Struts to Get??
    By milo033 in forum Brakes/Suspension/Chassis
    Last Post: 12-25-2010, 02:15 AM
  4. 1st gen needs new shocks....BAD.
    By mikefeelsgood in forum Brakes/Suspension/Chassis
    Last Post: 08-23-2009, 11:42 PM
  5. Blown Shocks
    By GOINDEF in forum Brakes/Suspension/Chassis
    Last Post: 06-22-2008, 09:33 PM
