Thread: rough idle / hunting problems
Results 1 to 8 of 8
  1. #1 rough idle / hunting problems
    Apr 2014
    New York
    I have a 02 GTP it has 122k miles. Its been running rough and hunting for idle also when I press the gas pedal while in park and release it the car almost stalls but it corrects itself. while I am driving and let off the gas to coast the rpms will drop down to about 700 - 800 rpm then go back up to 1200 rpm. I've changed the maf sensor twice since the stock one went bad and the replacement one also went bad. Also changed the iac valve, lower intake manifold gasket was replaced a year ago. I looked for vacuum leaks didnt find any. If anyone can help me I appreciate it thanks.
  2. #2 Re: rough idle / hunting problems
    Aug 2012
    Brooks, AB
    Did you replace the fuel injector o-rings? After doing the lower intake manifold gasket on my car, I had a rough idle that I could not figure out and it happened to be that I tore an o-ring.
  3. #3 Re: rough idle / hunting problems
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    With your key on push the pedal to the floor and hold it there for 5 sec. Then fully release and pump to floor 5 times in 7 sec. Turn key off then start.
  4. #4 Re: rough idle / hunting problems
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by lewis1952 View Post
    Holy crap was having the exact same problem the last 2 days..did this and it seemed to.work..no.more surging at idle...does this reset the tps or iac sensors?
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  5. #5 Re: rough idle / hunting problems
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    On man!
    Just picked up a GTP a few days ago. Did your trick here and now things runs even better! thanks dude..
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  6. #6 Re: rough idle / hunting problems
    Apr 2014
    New York
    Hi , thanks for your replies . Yes I replaced all the o-rings on the injectors. Yesterday my alternator started whining it did that once before about a month ago then stopped thought it was the supercharger at first. Is it possible a bad alternator can cause this. Im also thinking the maf sensor isnt working properly it is a reman from autozone.
  7. #7 Re: rough idle / hunting problems
    With ignition off, unplug the maf. Start it up and let the car run/get it's feet for a moment. Then drive and give it about 30 minutes to learn etc. Does it run better with the maf unplugged? If so..Maf is the likely culprit.
  8. #8 Re: rough idle / hunting problems
    Apr 2014
    New York
    Should I drive it with maf unplugged ?
  1. Hunting Idle
    By kkobberstad in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-20-2013, 02:09 PM
  2. possible rough idle problems
    By 91gpse in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-11-2011, 11:54 PM
  3. 99 GT hunting idle issues
    By slvr99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2011, 11:09 PM
  4. Hunting at an idle
    By buthead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2010, 03:12 AM
  5. Rough/hunting idle
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2008, 11:22 PM
