dont even worry about it...it didnt make any sence to me either. but we will see if it starts up i just cant believe they wanted 300 for that sensor! i fell over laughing! but now my question is, how do i get to the harmonic balencer?
If you look at the top right of the page you will see a link for How To. Click on that and look for the write up I did on replacing the CPS. Its step by step.
You guys think maybe my plugs are the wrong ones and maybe thats why i got the random cylindewr missfire ? I'm using autolite 104's
well when i replace my spark plugs i'm thinking about getting the Autolite XP iridium Spark Plugs they r expensive but i'm sure they last longer and get much better spark.
104s are the correct plugs for your setup, what are you gapping them to? Ive used autolites for 3 years now with no problems. Are you getting P0300?
When i installed them i did it with a friend who defently knew what he was doing and i think he gapped at .50 or .55 i dont remember, they did fine for about a year until i got that code then it went downhile from there. Ill probably just need to get new plugs and wires, yeah it was a po300 i think, it was just a random cylinder missfire.
well.....surprise surprise, the new cam and crank sensors did not get it running....i hate this!!! but basically, i replaced the sensors today, put everything back on. and it now coughs when cranked over. does not start but a little combustion happens. i would post a vid of the spark tester and noid light running next to eachother but dont know how to save it to my comp haha....but the noid light fires in a non-consistant way. (should be that same length between light but there is not). but the spark is going full blast.
Well, I kinda had my hope pinned on the Cam sensor and I couldnt bring myself to point to the CPS, though I thought you were going to prove me wrong on that one, but even what I thought it was isnt it. So Im going to update the list, post it again and see what else we can come up with.
Heres what I got so far, I would have posted sooner but I was trying to help someone else troubleshoot, LOL.
Issue:
*Rough Idle
*Stalls
*SES Light (most likely a P0300)
*Wont restart
Work Done:
*Replace LIM gasket 3000 miles ago
*New Air Filter
*Fuel Pump can be heard activating and tested at the Schrader valve showing 42psi
*Spark at cylinders #1, 3 & 5, others were not tested
*New Spark plugs were installed, autolite 103's, gapped at 0.050".
*Replaced spark plug wires
*Replaced Fuel Pressure Regulator (Note: Started after replacing the FPR, ran for a few minutes and then died, again)
*Replaced MAP sensor
*ICM was tested and shows good.
*Replaced Crankshaft Position Sensor
*Replaced Camshaft Position Sensor.
Just asking because I dont remember asking before, but have you unplugged the MAF sensor just to see if it does anything different? I dont see how it could keep the car from starting, but everything that made sense has been ruled out so its time to look at some unconventional things I guess.
Man, I'm having ADD tonight, but it does cough when you crank on it.....have you tried giving it a little gas? It is very possible that it could be flooded....giving it gas will help clear the cylinder out.
Pull a pug to see if it smells like gas? if it's wet at all? that will tell you if a cylinder is flooded out. 103's are probably too cold for the car as it is, but it will absolutely not prevent it from starting or running....they just won't keep as clean as they should.
Also, did you ever replace that MAP sensor?
the above list looks good synth. and i have replaced the map. but have not played with the maf. i will try that now. and for you reptile, i have tried feathering the gas, but no different results occur...:th_angry-teeth:
If unplugging the MAF makes no difference, the next thing to try is to pull out the IAC and then try and start it. Dont unplug it, completely remove it and then try and start it. If that doesnt work Im going to have to go back to the drawing board and see what else there could be.
what is the IAC? and here is the link to the vid of the noid and spark on the #3 cylinder during crank. YouTube - timing issue?
The IAC is on the the throttle body along with the MAF and TPS (Throttle Position Sensor). The IAC or Idle Air Control is a stepper motor that opens and closes to allow air to get to the engine when its idling (because when you're idling the throttle plate is close and the engine would get no air if not for the IAC or you would have to keep the gas pressed down for it to open enough to allow air to pass) and adjusts depending on the requirements of the engine at idle.
They are not known for going bad, Ive rarely seen one go bad, but if you remove it and the car starts and runs (probably will run a bit rough or maybe even idle high rpm's) then we know there is an issue there or with the engine getting air.
I wouldnt worry about how the noid is lighting up just yet. Could be something funky with the noid itself. But its probably worth keeping in mind for now. Does it do the same thing on other injectors?
man, this sounds bad.
does your security light come on?
check ALL the fuses and relays. one bad one can render a car a paperweight.
when you hear it sputter..does it make a bubbling sound?
did you by any chance have the front cover off? you could have possibly have gotten a bad sensor when you bought it new....
test your old sensor and new.....
go through all your plugs! also make sure that the little fine black wire that is on your coil/CPS/CKPS sensor harness is properly grounded.
i will pull the IAC later when i get home, and the security light is flashing like normal, how do i check the relays? what do you mean a bubbling sound? and front cover? and i have no way to test sensors
pulled the IAC and tried to start but no change...unplugged the map but no change...checked compression, and as follows: #1-145lbs #2-120lbs #3-142lbs #4-140lbs #5-139lbs #6-145lbs slight collection of puss on oil cap. will replace the head gaskets later. but could the PCM be shot?
