Thread: running condition symptoms of a bad sc coupler
Results 1 to 8 of 8
  1. #1 running condition symptoms of a bad sc coupler
    Dec 2012
    troll land
    I know my coupler is bad. What are some running condition symptom of a REALLY bad coupler? Working out some bugs and wanna b able to rule it out. Thanks
  2. #2 Re: running condition symptoms of a bad sc coupler
    Omaha, NE
    You know your coupler is bad. The best possible thing you could do would be to replace it see what problems still exist.
  3. #3 Re: running condition symptoms of a bad sc coupler
    Dec 2012
    troll land
    Waiting on the oil atm
  4. #4 Re: running condition symptoms of a bad sc coupler
    Feb 2009
    flintnasty MI
    a bad coupler just makes noise, no other things will happen because of it.
  5. #5 Re: running condition symptoms of a bad sc coupler
    Oct 2011
    Toledo, OH
    False. However, your coupler would have to be REALLY REALLY worn out or broken to cause backlash in the gears, and you'd definitely notice that.
    7"
  6. #6 Re: running condition symptoms of a bad sc coupler
    GTP Level Member David99GTP's Avatar
    Florida
    I was about to post a question about mine and saw this thread. I have no idea what is wrong with mine. I sold it 3 years ago and it sat for the last 2 years. I bought it back and have been restoring it. Runs strong but there is a noise that matches the RPMs. It fluctuates evenly with RPMs does not go away when RPMs go up. It sounds similar to when a bearing in a pulley goes bad. Kind of a steady grind/whine noise. It isn't a rattle. Hard to tell but seems like it is somewhere in the snout. Car has 150k on it. Any ideas what the most likely cause could be?
    Thanks!!
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  7. #7 Re: running condition symptoms of a bad sc coupler
    Remove belt, take another drive. If sound is still there, you know it has nothing to do with the S/C belt system.
    If not there, diag further.
    Screw driver on the ear test can narrow things down and make sure no other pulleys are bad and fluids are full.
  8. #8 Re: running condition symptoms of a bad sc coupler
    Dec 2012
    troll land
    Prolly a bad snout bearing ....a dude on here rebuilds them
  1. Symptoms of a chipped piston
    By Gasnmyveins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2011, 10:54 AM
  2. Symptoms like a clogged cat
    By Sig in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2011, 06:30 PM
  3. Low Oil Pressure but no symptoms?
    By EJOUIE in forum General Tech Discussion
    Last Post: 06-09-2011, 09:10 PM
  4. car studdering and other wierd symptoms
    By copperpacecar in forum General Tech Discussion
    Last Post: 05-01-2010, 06:28 PM
  5. Are these symptoms of a bad hub assembly?
    By nawarkk in forum General Tech Discussion
    Last Post: 02-18-2010, 09:28 PM
