your all set then. i used a spray bottle, stuck the straw in the snout, and sprayed the oil out into the bottle from the sprayer.
then laid rags down on the lim, and the front of the lim to cover the timing cover area. cause some will spill out when you pull the snout off. mopped that up, then sprayed it down with brake cleaner.
same with inside the snout, and the gears. spray it all down. i used a full can of brake cleaner.
