Thread: please help!
Results 1 to 20 of 23
  1. #1 please help!
    Jan 2014
    St. Louis, MO
    So this car after head gasket rebuild in such...I ran a hose thru to clean coolant out and saw that the rear freeze plug was missing closest to passenger side. Please tell me I can replace this without pulling motor or dropping trans?!
  2. #2 Re: please help!
    GTP Level Member GrandPrixgtp2000's Avatar
    Madrid Iowa
    that might be a hard one to do man. when your under the car can you see it?
  3. #3 Re: please help!
    Jan 2014
    St. Louis, MO
    Yes looks like the motor mount right under it :/
  4. #4 Re: please help!
    your choice, pull the engine, or the tranny. you may of had a shot while the heads were off, but i guess they are back on now.
  5. #5 Re: please help!
    Jan 2014
    St. Louis, MO
    Dammit all to hell!! Yea heads are back on with everything else no other possible way?
  6. #6 Re: please help!
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Can you get your hand to the hole? If you can get a screw type freeze plug. They work just fine especially when you don't have room to pound a new one in.
  7. #7 Re: please help!
    no way my hand will fit in there from the bottom. theres like maybe 3 inches of space between the trans pan and oil pan.
  8. #8 Re: please help!
    Jan 2014
    St. Louis, MO
    Hmm from top of car I can put my hands there and put my fingers in the hole (lmao thats what she said) so I bought a few different size rubber freeze plugs and praying that I can tighten one up back there! I feel I may be able to... it will suck but would be best n my situation at the moment lol
  9. #9 Re: please help!
    i posted in chat, not sure if you saw or not. but a block heater fits in a freeze out plug hole, you may be able to pop one of them in there. they slide in the hole and a bolt makes it tight, like a molly type deal.
  10. #10 Re: please help!
    Jan 2014
    St. Louis, MO
    Hmm really? What would that cost and what size? I can try that too I just need this plug in long enough to see how motor acts after rebuild before I pull motor! If I pull the motor I may replace whole block but at my current position may take a bot for me to get :/ so that's why im trying several options before I pull it... btw scottydoggs you've been extremely badass with all your help man thank you
  11. #11 Re: please help!
    http://www.ebay.com/itm/GM-12498691-...9e7f48&vxp=mtr
    search around some more they can be found cheaper then this.
  12. #12 Re: please help!
    Mar 2012
    NC
    You can by them at Advance Auto/Autohut/O'Reilly's for like $10-15.
  13. #13 Re: please help!
    Jan 2014
    St. Louis, MO
    would a block heater be easier to install than a rubber expansion plug?
  14. #14 Re: please help!
    Mar 2012
    NC
    Probably about the same...but at least the block heater is dual purpose lol
  15. #15 Re: please help!
    never saw one, so i dont know how it works.
    block heater is nice to have. and if you can install it it solves your issue permanently.
  16. #16 Re: please help!
    Plus no more cold starts in the winter if you plug it in lol.
  17. #17 Re: please help!
    Jan 2014
    St. Louis, MO
    So i was able to fit the rubber freeze plug in their quite nicely and finally started her up today Ill upload a video to show
  18. #18 Re: please help!
    Jan 2014
    St. Louis, MO
  19. #19 Re: please help!
    Aug 2011
    'Merica
    Ahh ****....
  20. #20 Re: please help!
    Jan 2014
    St. Louis, MO
    What happened?
