Thread: Overheating issue =-(
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Overheating issue =-(
    Mar 2012
    NC
    Not necessarily Scotty...especially if he's only ever pushing air due to having an airbound system.
  2. #22 Re: Overheating issue =-(
    Mar 2012
    NC
    Regardless, I still say he replaces the T-stat, bleeds it as outlined, and fixes that overflow hose...then we'll see what happens.
  3. #23 Re: Overheating issue =-(
    Oct 2012
    Hey Guys thank you for all the help.
    The "straw" from the top of the reservoir cap fell to the bottom. I pulled the reservoir out, dumped the coolant in a clean bucket and fished out the straw. I think over the years it expanded and it was super loose on the cap. Anyhow i put a ziptie around it...then put everything back together. Filled the reservoir up a bit and started the car with the Rad cap off. I followed Scottie's directions to bleed the system and it went much better this time, when the fans started i bled it until i got a good solid stream, then topped off the rad side and capped it. Engine temp is normal now =-) Thank you so much for the help guys!
    I think last night i was just not bleeding it properly or something because it doesn't make sense to me why i just kept getting steam even though the straw had fell off the cap.
    I think the straw fell off a while back....its my GF car so i don't drive it everyday...anyhow i noticed it was missing when i squeezed the tube from the rad to the LIM i could hear it trying to "suck" back and forth on the reservoir cap...so i assume what happened is that over time it just collected air in the coolant system...eventually causing it to not run at the proper temp!
  4. #24 Re: Overheating issue =-(
    sounds good. just tell her to keep a good eye on it for the next week.
  1. Overheating Issue
    By Big Poppa Pump in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2013, 11:16 AM
  2. Overheating issue please help
    By 98gtp86 in forum General Tech Discussion
    Last Post: 06-02-2013, 11:41 PM
  3. Overheating issue
    By Below Average Joe in forum General Tech Discussion
    Last Post: 11-13-2011, 11:42 PM
  4. overheating issue
    By alreadytooken in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-29-2011, 10:28 PM
  5. overheating issue
    By doc7000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2008, 01:18 AM
