Thread: Battery and fusebox relocation
Results 1 to 20 of 22
  1. #1 Battery and fusebox relocation
    GT Level Member m17davis's Avatar
    Orland Park, IL
    So one thing led to another and I got carried away. I don't understand the how to for relocating the battery. Do I just use the stock harness in this picture and extend the power wire to the fusebox, and extend the power wire to the starter? Then just ground the little one and the other ground that is usually by the starter, in the trunk in 2 different spots?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: Battery and fusebox relocation
    Well you have:
    2 power wires that go to the battery
    Then 2 grounds.
    Run the power wire from the starter directly to the battery in the trunk
    The next power wire goes from the fusebox to the battery...
    Or
    you can run the cable from the starter to either a distribution block in the engine bay or a distribution post and then run a cable from the distribution post to the battery
    Next you can run a positive cable from the fuse box to the distribution block or distribution post
    The grounds
    Run a new cable from the trans housing directly to the battery.
    The next ground you can find a decent spot in the trunk (maybe strut tower) to run the second ground
    If you do it this way you'll just have 2 cables (one +, one ground) running the length of the car
    Or you can just skip the whole distribution block or post thing and run the starter cable directly to the battery and then run the fuse box cable directly to the battery as well.
    And while your at it run a new power wire from the alternator to either the fuse box or from the alternator to the battery of from the fuse box to a distribution block...
    And add a circuit breaker for the battery in the trunk somewhere
    Make sense?
    04 Comp G.
  3. #3 Re: Battery and fusebox relocation
    Orland Park, IL
    Absolutely. Thank you so much. Im thinking I should run a 0 from the battery to a distribution block by the trans close to the firewall. Maybe next to the booster? And from there go to altenator and starter. Than from fusebox in the center counsel to the battery. And then grounds are pretty self explanatory.
    If im understanding this than that should work?
  4. #4 Re: Battery and fusebox relocation
    Yup that should work just fine. Good idea actually.
    04 Comp G.
  5. #5 Re: Battery and fusebox relocation
    Arizona
    For my batt relocate I have battery in trunk grounded to spare tire well area with 2gauge then another 2 gauge that runs up from to engine block. Power wire is a 0 gauge that runs to distro block where the alternator with 2 gauge meets it and starter. I then have 0 gauge piece from distro block to fusebox
    Factory ground to battery is grounded where the battery tray used to go.
  6. #6 Re: Battery and fusebox relocation
    Orland Park, IL
    Thanks. Im going to do a massive wire tuck so I was thinking where can I put it and have it not be seen. I thought you should never have a smaller ground then power...? so you took the ground that was on the trans and just put it right in the spare tire area and the other ground is where the battery used to be?
  7. #7 Re: Battery and fusebox relocation
    Hmm guess I need to dig up some 0 gauge I was planning on just using some 4 gauge welding cable for everything.
    04 Comp G.
  8. #8 Re: Battery and fusebox relocation
    Orland Park, IL
    I have a **** load of 4awg. I wanted to try and use that from battery to fusebox , and from distribution to alt and starter
  9. #9 Battery and fusebox relocation
    I'm pretty sure I have a bit of 0 gauge leftover from KnuKoncepts but won't be enough to run it to the trunk and it's really thick so wanted to go with something that will be easier to route.
    04 Comp G.
  10. #10 Re: Battery and fusebox relocation
    Orland Park, IL
    How much do they change for 0 by the foot out by you
  11. #11 Re: Battery and fusebox relocation
    I haven't bought any in awhile and when I did I order it online most of the time. Last time i tried to buy some around here it was something like $3 a ft or something ridiculous around here.
    04 Comp G.
  12. #12 Re: Battery and fusebox relocation
    Nov 2011
    NY
    1/0 is way to go...
    You should probably upgrade your Alt to a higher output too...
    Is what I'd do if or when moving battery to trunk.
    Maybe not needed but Just my $.02
  13. #13 Re: Battery and fusebox relocation
    Upgraded alt is not needed. As long as whatever alternator he has on there now is functioning properly he"ll be fine. High output alt is a waste of money unless he has a high end crazy system.
    04 Comp G.
  14. #14 Re: Battery and fusebox relocation
    Orland Park, IL
    Over here its $3 a ft for 4awg. What is 1/0? I want to relocate the alternator to where the a/c compressor is. Do you know which one would bolt on? Or if I need a custom bracket
  15. #15 Re: Battery and fusebox relocation
    Arizona
    Since I have 3 ground location points and there tied together I don't need tonworry about my ground cable size there all bigger than 4 gauge anyway.
    I wouldn't bother with the alternator unless your car is dying on you.
    I got my 0 gauge off eBay for 28bucks shipped for 25ft worth of high strand oxy free cable. I also made it a point to solder every lug and crimp it.
    And negative the ground on the trans is still there but my battery is grounded there to the same point which ties back to the battery tray location. I also have the battery additionally ground in the spare tire well.
  16. #16 Re: Battery and fusebox relocation
    Stock wiring is what 6 gauge for the most part?
    04 Comp G.
  17. #17 Re: Battery and fusebox relocation
    Arizona
    On the LS4 harness it was 4 actually but ****ty low strand cable
  18. #18 Re: Battery and fusebox relocation
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    I used 6 gauge for the relocation to the trunk on my GTP. It works pretty good in the warmer months but when it gets cold you'll regret not going bigger. I also have a 1000 cca top post battery in the trunk so if you have a smaller battery than that your definitely gonna want to go bigger with the wire gauge.
    Also don't ever let the battery go dead. The when you go to start the car the key gets stuck in the ignition. The battery is dead so you can't pop the trunk and unless you have a spare you can't open it from the outside. I really regret relocating it to be perfectly honest.
    I went NA when a whore left -$300 in my bank account.
  19. #19 Re: Battery and fusebox relocation
    Kemmerer, Wyoming
    for us simple folk, can I just run a wire from the negative terminal and a wire from the positive terminal and then move the battery to the trunk?
  20. #20 Re: Battery and fusebox relocation
    Dec 2014
    United States
    Anyone have pics of this? Write up maybe?
  1. trouble shooting trunk release, found sensors behind fusebox..?
    By vegasridercc in forum General Grand Prix Discussion
    Last Post: 09-21-2012, 10:42 AM
  2. Engine fusebox wires melted
    By Bluemagic in forum General Tech Discussion
    Last Post: 09-08-2012, 03:46 PM
  3. new fusebox cover and cross braces
    By beckys2000gt in forum Visual/Body Modifications
    Last Post: 06-26-2010, 10:12 AM
  4. Custom Fusebox & Underhood Lining
    By Spartan GL in forum Visual/Body Modifications
    Last Post: 01-20-2010, 12:16 AM
  5. Battery relocation question - windshield washer tank
    By roboz in forum General Tech Discussion
    Last Post: 07-11-2009, 02:51 AM
