alright will be heading to NAPA in a bit here. anyone got a write up on how to swap the t-stat on my baby?
On a cold motor, remove the two 10mm nuts on the thermostat housing, remove the tstat and install the new one with a gasket. Bolt the housing back on and top off the coolant.
You might loose a cup or two of coolant but thats it. You don't even have to bleed the system if you do it cold.
wicked, thanks for the info! ill let u know how it goes
delete the egr. Take any piece of metal drill 2 holes for bolt, use high temp gasket sealer. Get a screw I plug for the exhaust. I would change the coolant sensor too. Some call it the master sensor cause it virtually runs everything under the hood.
Sounds good. Gonna try this in Sunday possibly if I get the time.
Appreciate all the tips/info!!
So changing the t-stat did not work with the temp gauge. Still reads low. Maybe it went up 2 ticks on the gauge... Now what's next? Is there a temp gauge sensor?
Yes, the coolant temp sensor that is screwed into the LIM. Should be near the t-stat housing and under the exhaust crossover.
K that ****er is next!
