Thread: Upper intake gasket
Results 1 to 3 of 3
  1. #1 Upper intake gasket
    Jan 2014
    Kentucky
    Do I need to put any RTV on the gasket where the blower bolts to the LIM or just orings and gasket??? The reason I ask is when I took it apart it was covered with red RTV! The gasket has a small bead of some kind of sealant around it I was just curious before I bolt it down.
    THANKS
  2. #2 Upper intake gasket
    Nope you don't if you use a new sc gasket it should have a small bead of rtv on it already so no additionally needed.
    Edit: of course make sure you have the 2 yellow orings installed.
    04 Comp G.
  3. #3 Re: Upper intake gasket
    Jan 2014
    Kentucky
    COOL Thanks ALOT I just wanted to make sure. I know if I have any ?s I get the best answers here. THANKS ALOT FOR THE HELP!! I am going to try and get her together today.
  1. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  2. So I replaced upper intake manifold gasket
    By jmn in forum Introductions/Noob Questions
    Last Post: 11-07-2013, 08:50 AM
  3. tips/tricks. list for upper/lower intake manifold gasket job..
    By crod in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-30-2012, 12:51 AM
  4. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
