Thread: Harmonic balancer
Results 1 to 10 of 10
  1. #1 Harmonic balancer
    GT Level Member dezebe1's Avatar
    May 2013
    Dallas TX
    The other day i was doing some digging online for a harmonic balancer for our LeMons race car due to the fact that we are going from N/A to Supercharged. Looked at aftermarket SFI balancers and figured we need to keep the engine looking stock so in my search I found a different part number between a GTP L67 and a Bonneville L67. Had our parts dept. pull the factory GM part nubers for each and found the Bonneville balancer is 3lbs. heavier. GTP 8.5lbs vs. SSEI 11.5
    So figured I'd pass it along if anyone is looking for a beefier stock factory balancer that will help control harmonics better.
    Team JB-Weld
  2. #2 Re: Harmonic balancer
    Thats kind of odd. And you got those part numbers lol?
  3. #3 Re: Harmonic balancer
    May 2013
    Dallas TX
    Quote Originally Posted by slick2500 View Post
    GM part #12563266 for the Bonneville balancer and 12563268 for the GTP balancer
    Team JB-Weld
  4. #4 Re: Harmonic balancer
    Dec 2012
    troll land
    I wonder if its the same for a park avenue?
  5. #5 Re: Harmonic balancer
    Mercer, Pa
    Park Avenue and Bonneville have same motor mounts and pulleys, the balancer would be the same. Sure your comparing supercharged balancer from ssei with the gtp?
  6. #6 Re: Harmonic balancer
    http://www.amazon.com/ACDelco-125632.../dp/B0049Z6VTG
    http://www.amazon.com/ACDelco-125632.../dp/B0049Z4TMW
    they looks the same to me, i wonder where the extra weight is? they dont list the weight on the ads.
  7. #7 Re: Harmonic balancer
    May 2013
    Dallas TX
    The Bonneville is a thicker outer metal ring...same diameter overall just thicker. I had both up at the parts counter and put both on our shipping scale at the dealership. Feels much beefier also.
    Disclaimer.....I'm not saying this aving the complete rotating assembly is the correct one for a GTP but for our race car we perfer to use it due to the fact we will be having the complete rotating assembly balanced with new JE pistons, ARP rod bolts so just wanted to share if anyone else is looking for another alternative
    Team JB-Weld
  8. #8 Re: Harmonic balancer
    May 2013
    Dallas TX
    Quote Originally Posted by sseilmnop View Post
    if you don't belive it you can even look up the difference on rock auto. So yes I am 100% sure and I didn't mention anything about a Park Avenue. Look them up both as a 2003 model year
    Team JB-Weld
  9. #9 Re: Harmonic balancer
    hangover park IL
    its mostly for NVH reasons the luxury cars got the heavier damper, so yeah its better but only to the point that its optimal damping rpm is well below what we run. remember calculated life at wot was less than 5%, mostly the motor turns under 3k as its a low/mid range tq monster.
    also with as many outer rings ive seen seperate...id stick with sfi
    ~James~ Psychotic Gearhead
  10. #10 Re: Harmonic balancer
    May 2013
    Dallas TX
    If you scroll down it shows the weight diference
    Team JB-Weld
  1. Harmonic balancer
    By Tone5500 in forum General Tech Discussion
    Last Post: 11-13-2013, 08:01 AM
  2. Well there goes my L67 harmonic balancer...
    By jlgp2007nc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 02:44 PM
  3. new harmonic balancer, now got KR
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 07:31 AM
  4. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
