Thread: 2003 GTP from auction - low MPG
Results 1 to 15 of 15
  1. #1 2003 GTP from auction - low MPG
    Jan 2014
    Woodstock, GA
    Former '08 GXP owner here, which I sold a few months ago. I "replaced" it with an '11 Civic Si... big difference between the two! The Civic is fun in it's own way and is a tight, well built car - but no V8.
    So I missed my GP and got an '03 GTP It was had for a reasonable price at auction, knowing I'd need to do some work on it. 120k miles. The body is in pretty good shape, the interior is ok, and I think the mechanics will need the most work.
    First thing I noticed is the MPG on the DIC is low. It was showing an average around 13.5MPG. I reset it and it is 11.8 or so, climbing back up slowly.
    Went to get emissions and it doesn't have enough data stored to pass, which means the battery was probably removed before I bought it. Wonder how long before the check engine light comes on...
    Any suggestions on what to look for in regards to low MPG? O2 sensor? If so, which one? Any other items?
  2. #2 Re: 2003 GTP from auction - low MPG
    St. Louis
    Dirty MAF, vacuum leaks (especially at the "T" under the S/C snout), fuel filter, air filter, plugs, wires, tires properly inflated. I'm sure you know, but be sure to run at least 91+ octane in it always.
  3. #3 Re: 2003 GTP from auction - low MPG
    Jan 2014
    Woodstock, GA
    Quote Originally Posted by FordMan77 View Post
    Great, thanks for the ideas to get started. I have not even put gas in yet, but I'm used to the 93 on a few cars.
  4. #4 Re: 2003 GTP from auction - low MPG
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Could be tstat also if the car isn't warming up mpgs go kerplunk.
    Sent from my HTC Thunderbolt using Tapatalk
    2012 F150 STX
    - Gonna be a race truck
  5. #5 Re: 2003 GTP from auction - low MPG
    Florida
    Just for peace of mind, I'd go ahead and replace the vacuum lines and tee's, plugs, plug wires, all fluids, filters, check tire pressure, clean the TB and all the sensors in it (with the proper cleaner) check tire pressure, and ensure that the o2 sensors are properly switching.
  6. #6 Re: 2003 GTP from auction - low MPG
    SE Level Member Snoop dogg's Avatar
    Dec 2013
    chicago
    wat should the MPG be for city diving cause mine show 15.2 on DIC
    ....::::THE DREAMER::::....
  7. #7 Re: 2003 GTP from auction - low MPG
    Apr 2012
    Dayton, OH
    Depends on temps
    2012 F150 STX
  8. #8 Re: 2003 GTP from auction - low MPG
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    Depends on temps
    Idle time, driving habits, and traffic movement also have an effect. This cold weather makes mine read about 17-17.5 because I illet it run for 15-20 min to warm up in the morning and after work before I leave. During summer I average around 20.
  9. #9 Re: 2003 GTP from auction - low MPG
    Dec 2013
    chicago
    ^ I let mine warm up about the same time but my temp stay in the middle of 160 and 210 no higher unless I'm low on antifreeze
  10. #10 Re: 2003 GTP from auction - low MPG
    Nov 2011
    NY
    Depends on temps
    Depends on a lot of things, not just temps! Maintenance, fluids, lube, suspension, gas, tires, elevation, temperature and most importantly... FOOT! The FOOT mod, although little known and understood, is the biggest mod with effect on efficiency! A Bad foot mod could cost as much as 5-10 MPG. Rarely discussed but well known by all the old schoolers, you'd have to search high and low for just a glimpse of a well developed and utilized foot mod. It's a secret not readily shared either and you need to be IN the know in order to get the information n how to use it properly. Many have tried and failed, succumbing to the ever present temptation to abandon it and leave it all to its own. The FOOT...
  11. #11 Re: 2003 GTP from auction - low MPG
    Apr 2012
    Dayton, OH
    Well I said that based on I usually get 16 city then I'm getting 9 now lol. Freaking cold, yes I was s little vague.
    2012 F150 STX
  12. #12 Re: 2003 GTP from auction - low MPG
    Jan 2014
    Woodstock, GA
    So I found a leak around the TB gasket and replace the gasket. I don't know how much of a factor this is for the mileage but there was a definite leak on the bottom side. Clean the TB while I had it off.
    Also cleaned and oiled the air filter (K&N). Replaced the thermostat.
    Can anyone give me a part # for a set of tees and vacuum lines? The coupler for the line from the TB to the evap canister broke off a piece.
    Will see how much difference the gasket made... more to come...
  13. #13 Re: 2003 GTP from auction - low MPG
    Only dealerships have the line part numbers, and are the only ones to sell the lines as a whole.
    Most people just buy vacuum tubing and some plastic T's and make there own lines, normally it's cheaper and quicker.
  14. #14 Re: 2003 GTP from auction - low MPG
    i used a fat line that fit the large tube on the TB, then pushed a thinner line inside it, then pushed the stock plastic line into the thin line.
    50 cents worth of vac tubing.
    dont over oil that filter, they tend to kill maf sensors.
  15. #15 Re: 2003 GTP from auction - low MPG
    Jan 2014
    Woodstock, GA
    Thanks to everyone for the help. I'm up to 17.2MPG for short city trips. That's pretty good I figure.
    Next on the hit list is replacing the wheel hub assemblies (due to loud road noise when driving) and then LIM replacement. Any tips for either are appreciated! I found some good DIYs for both and I ordered a set of 2003 service manuals off eBay
  1. Buying at an Auction
    By Vegito in forum Off Topic Discussion
    Last Post: 06-15-2010, 09:59 PM
  2. Burned on an eBay auction
    By Deezul_AwT in forum The Rant Forum
    Last Post: 02-22-2008, 01:07 PM
  3. barrett-jackson auction
    By MTXGTP in forum Off Topic Discussion
    Last Post: 01-17-2008, 12:44 AM
