Thread: Most Likely a Blown Head Gasket
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Most Likely a Blown Head Gasket
    Mercer, Pa
    The hole must be sealed to LIM (no hole in LIM) and not leak over to bypass hole which. This hole is part of the internal PCV and should not leak to inlet of LIM.
  2. #22 Re: Most Likely a Blown Head Gasket
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Wait, what flows through this hole and why? If it's supposed to go to a hole in the LIM that doesn't exist, what would be the point of that?
  3. #23 Re: Most Likely a Blown Head Gasket
    Mercer, Pa
    It's a curved slot on the gen 5's.
  4. #24 Re: Most Likely a Blown Head Gasket
    Mercer, Pa
    It's a hole in the casting that is sealed by the LIM. If it leaks at the gasket over to bypass hole it will push up dipstick.
  5. #25 Most Likely a Blown Head Gasket
    Mercer, Pa
    The spot on LIM where it seals.
  6. #26 Re: Most Likely a Blown Head Gasket
    Aug 2011
    Michigan
    So do I block off that hole on the supercharger itself? Or just in the intake manifold? Or both? And what do I use to block the hole off?
  7. #27 Re: Most Likely a Blown Head Gasket
    Aug 2011
    Michigan
  8. #28 Re: Most Likely a Blown Head Gasket
    Mercer, Pa
    The hole is blocked by gasket and LIM but people have been none to add RTV. If you add RTV you may not compress the gasket here and it won't seal well.
    Like I said take belt off so you get no boost. If the dipstick stays in you have a Boost leak from lim or super gasket (actually called plenum) somewhere to the crankcase.
  1. Blown Head Gasket?
    By cajun98 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-29-2013, 08:34 PM
  2. Blown Head Gasket?
    By MNGPGT in forum General Tech Discussion
    Last Post: 10-02-2012, 04:00 PM
  3. cracked head blown head gasket or just done??
    By roytoy70 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2012, 10:40 PM
  4. Blown head gasket?
    By tjhgtp86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 04:01 AM
  5. Possible Blown Head Gasket
    By Blk99GpGt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-09-2009, 12:40 PM
