Thread: Catalytic converter?
Results 1 to 9 of 9
  1. #1 Catalytic converter?
    Aug 2008
    SOUTH TEXAS
    I'm told my kr problem might be related to the cat conv being clogged up.
    Being that my car is runing rich,it might of clogged it up.
    Reason for my afr ratio to be 10.5@wot.
    Is it safe to run with out one?
    Will it affect perfr any?
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  2. #2 Re: Catalytic converter?
    Donating Users blowfishRus6's Avatar
    g.a.
    i dont have one and i havent seen any ill effects. you wont pass emisions tho
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: Catalytic converter?
    you can pass emissions so long as they dont do a visual check. you just have to use an o2 sim or set the SES code to no report for the rear o2.
  4. #4 Re: Catalytic converter?
    g.a.
    humm. well there you go
    its slow.
  5. #5 Re: Catalytic converter?
    May 2008
    staten island,NY
    i run a catless dp with an o2 sim for over 3 years now, no issues
  6. #6 Re: Catalytic converter?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by GTP4 View Post
    Well if your cat was clogged up you'd be seeing abnormally high boost numbers. How much psi are you seeing at wot?
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  7. #7 Re: Catalytic converter?
    Aug 2008
    SOUTH TEXAS
    Quote Originally Posted by Smokin2000gtp View Post
    Here is the scan on the last run:
    12052008_211926.csv from slow6 -- Scan Depot dot net
  8. #8 Re: Catalytic converter?
    ^^ good point, didnt think of that.
    youre making 11psi on a 3.2 which is about right. have you tried leaning it out, or no matter what you do it is always rich?
  9. #9 Re: Catalytic converter?
    Jul 2008
    Dekalb, IL
    Ya boost looks fine. Definitely lean it out some, if you still get a good amount of KR then pulley up.
  1. choppin out catalytic converter
    By gtpinsc in forum General Tech Discussion
    Last Post: 12-31-2008, 01:18 PM
  2. 2001 pontiac grand prix catalytic converter
    By Reeddawgy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2008, 07:13 PM
  3. Very Good Catalytic Converter Information
    Last Post: 03-02-2008, 09:15 PM
  4. Catalytic Converter Theft
    Last Post: 02-24-2008, 09:49 PM
