Thread: SD Headers and AEM Wideband O2
Results 1 to 20 of 20
  1. #1 Re: SD Headers and AEM Wideband O2
    Florida
    You can use the rear o2 bung, but the values will be slightly different from doing it more upstream. I ended up having another bung welded into the downpipe portion for $10 since I am catted and using both narrowbands
    And yes, you can use the same gauge/sensor as of their 4.2 sensor. check out the site if you want, under key features
    http://www.aemelectronics.com/wideba...fuel-gauge-25/
  2. #2 Re: SD Headers and AEM Wideband O2
    Mar 2012
    South Beloit, IL
    Okay thanks! I am guessing the values are slightly off because the EGT is lower downstream? Is this enough to affect the performance of the gauge or should I just do it right the first time and have the bung welded in?
  1. Wideband
    By GAFF in forum General Tech Discussion
    Last Post: 10-27-2010, 02:57 PM
