Thread: SLP Header Installed
Results 1 to 20 of 57
  1. #1 Re: SLP Header Installed
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I emailed BRISK about what plug to use on a mildly modded 3.8l s/c V6 with about 11PSI, and got this response today:
    Hi Lee,
    the spark plug you need is Brisk Silver Racing G14YS. That is a spark plug specially designed for forced induction applications, nitrous or methanol injection.... and we have many vehicles with over 3500Hp running the Brisk Silver Racing plugs and setting world records. The LGS is excellent choice for N/A and stock boost forced induction applications. Your vehicle have powerfull ignition system and will handle the GOR14LGS plug at your boost level, but due to the higher boost and altered A/F ratio the lifespan of the plug will be relatively short.
    Hope this info will help.
    Best regards,
    Chris
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: SLP Header Installed
    SE Level Member crashman's Avatar
    Perry Hall, Maryland
    Do ya have ANY words of wisdom & wit for your header installation??
    I've got a set of SLP headers that I'm itchin' to put in. Got any tips??
  3. #3 Re: SLP Header Installed
    Port Hope Ont,Canada
    Hi Chris
    yeah i sure will
    do a scan for you...
    I will put the scan on and do a long run with it
    and post up the findings....
    The plugs i just took out were installed in Sept 29th 2007
    and were AC Delco 12568387 -- ITR 4A -- 15
    I believe this is a stock plug for the GTP's..
    The scan that is on here now was taken while sitting in the parking lot,
    and was done as it just warmed up..
    I will do a proper reading and post it up soon.
    I will find out what plug the one guy is useing..
    as he has alot of boost i believe around 10 or 12 PSI
    But don't quote me on that as i am not sure..
    and has a cam rockers et... he is in the 12 sec club so has
    some work done.. --->He uses the same plugs GOR15LGS
    we went for a long run tonight to Toronto which is about 135 miles
    from here on the 401.
    All i can say is wow awsome responce and power is right there.
    As is it is hard to tell jumping from the AC Delco to these,
    and would like to test the 104's and these to see the difference..
    Thanks John
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
  4. #4 Re: SLP Header Installed
    St Louis MO
    Quote Originally Posted by J_Ferguson View Post
    Hi Chris
    yeah i sure will
    Thanks John
    I would waste the time trying AL 104's they are just a plug and nothing special.
    I never got a response to my second email about running their non resistor plugs. I remember these now. Last time I did the email thing with them I couldn't get consistant answers.
    2010 Camaro SS LS3
  5. #5 Re: SLP Header Installed
    That is to bad..
    I hate that when companys
    will not answer questions or responces..
    I'm going to give them a call also..
    Thanks John
  6. #6 Re: SLP Header Installed
    St Louis MO
    That is to bad..
    Thanks John
    I think I'm going to call them. I like the idea of silver plugs because of their electrical and thermal properties. Of cousre copper has better properties than iridium and the iridiums seem to be a better plug for my car.
    I'm going to call Brisk later today and find out why they recommended a non resistor plug for my car. Since I am a sparkplugaholic, I almost have to try something they offer in a silver.
    2010 Camaro SS LS3
  7. #7 Re: SLP Header Installed
    Oklahoma
    Quote Originally Posted by IndeedSS View Post
    You and I have something in common. I try just about all of them that come out. The most recent ones I tried were E3 plugs. I cant say they got a good test because one of the plugs failed on me. It shorted out which I dont think I have ever seen a plug do, but it shorted out internally.
  8. #8 Re: SLP Header Installed
    Well is way to soon to be saying this,
    But i have had the plugs in since Thursday
    and i am still very much impressed....
    Our gas milage around town has improved..
    we were getting 21 to 22--- is is now holding at 25
    for city driving.
    Hwy driving was at 28 to 31 and now is 35.8
    Traffic pendending...
    The motor once it warms up is just awsome
    and very smooth and can still feel the difference
    in the power..
    But like i said is still to early to be making judgement calls
  9. #9 Re: SLP Header Installed
    Quote Originally Posted by crashman View Post
    None really unless you have fat forearms like i do...
    then roll up them sleves
    Losen up the front header first, then remove the dog bones
    and roll the motor forward, Tie it forward to the front suport
    If you are not sure of the fireing order then before you remove the plugs
    tape them were they go.
    They were pretty easy to install, and my only hard part was cutting the
    pipe after the flex and installing the new flex...
    I did go down to my local shop to put it up on the hoist
    but that was because it was raining and $50.00 bucks compared
    to laying on the ground in the cold and rain---> = $50.00 bucks
    well spent
    I was at first thinking i would have to remove the TB and such
    but you will see as you go it is not that bad at all...
  1. Just installed wizaired CAI
    By 3800SE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2008, 07:46 PM
  2. TOG Header Question...
    By Iron Indian in forum General Tech Discussion
    Last Post: 01-09-2008, 01:00 AM
  3. Got my TSW Mondello's installed (sort of)
    By GeddyLee in forum Off Topic Discussion
    Last Post: 12-30-2007, 06:50 PM
