Thread: Performance Shifting
Results 1 to 8 of 8
  1. #1 Performance Shifting
    Nov 2008
    Minnesota
    I just recently bought a 1998 GTP and I looked in the owners manual to see what the button on the side of the shifter was. Seeing that it might be nice, I went to try it out, but the "PERF SHIFT" light didnt come on, and I was wondering how you would know if it was actually on?
  2. #2 Re: Performance Shifting
    TDCRacing
    Guest
    Well it would be kind of hard as it only changes the shift points a cupple hundred rpm's. Maybe someone else would have some suggestions for ya.
  3. #3 Re: Performance Shifting
    Aug 2008
    SOUTH TEXAS
    I had a 98 previous to my 99.
    And the light would come on on the corner of the dashboard in the cluster, where as my 99 lights up on the dic.
    Like said, the shifts will be firmer so its noticeable.
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  4. #4 Re: Performance Shifting
    Nov 2008
    Minnesota
    Well, I dont see a light, but I can def. tell a difference in the shifting, maybe the light just doesnt work...
  5. #5 Re: Performance Shifting
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    You should be able to tell a difference. My light in the cluster burned out as well....
  6. #6 Re: Performance Shifting
    Dec 2008
    Canada
    Yeah when I drive mine you can feel a clear difference, I also have a 1998 GTP and the light burned out I thought it was a different problem but it was the light always check the cheaper problem first haha so when I bought the car I just replaced it.
  7. #7 Re: Performance Shifting
    You can run a wire I believe to the PCM (slot 23 I think) and it'll activate the light in the DIC...PYFC.com sells a Perf. Shift Harness Kit, since the '03's didn't come with it and I know nothing about wiring I bought it and installed it in about 30-45 minutes.
  8. #8 Re: Performance Shifting
    GT Level Member gtphayes's Avatar
    Nov 2008
    harpers ferry, Wv
    well before all that. have you tried it at night? mines hard to see during the day. gotta angle my head all weird to see it. but at night it's a clear blue light right above the rpm's between 1-2k i think. i have a 98 as well.
    ---under construction---
  1. Hard shifting
    By Seagya in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2009, 09:50 AM
  2. Shifting 1,2,3 before 20 mph!!
    By fratzke7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-30-2008, 06:22 PM
  3. Performance shifting
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 06-01-2008, 08:58 PM
  4. Manual shifting
    By JCG's-GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-01-2008, 10:47 PM
  5. Another shifting from CGP
    By gp2000gt in forum Introductions/Noob Questions
    Last Post: 01-28-2008, 04:07 PM
