Thread: No fire after LIM gasket work...
Results 1 to 20 of 29
  1. #1 No fire after LIM gasket work...
    Sep 2011
    Canada
    I changed the upper, lower intake gaskets, throttle body gasket and valve cover gaskets. I double and triple checked the electrical connectors and everything is connected. I did the spark test putting the screwdriver in the spark plug boot when turning it over and I have no spark.
    I'm leaning towards the connector on the ICM, and checking the coils. Does anyone have any other advice for me? Something else I should check?
  2. #2 Re: No fire after LIM gasket work...
    is it getting gas? see if its got fuel pressure at the rail.
  3. #3 Re: No fire after LIM gasket work...
    Sep 2011
    Canada
    Yup I got fuel, I checked for pressure and I have fuel.
  4. #4 Re: No fire after LIM gasket work...
    did you take the coil bracket off? theres a ground wire that needs to be bolted back on the side of the head by the sc tensioner
  5. #5 Re: No fire after LIM gasket work...
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Check your battery connections!
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  6. #6 Re: No fire after LIM gasket work...
    Sep 2011
    Canada
    My battery connections are good. @Scottydoggs I think I put that ground wire on the dogbone bracket. Can you give me a bit more detail to where it's supposed to be bolted to. Thanks.
  7. #7 Re: No fire after LIM gasket work...
    move it to the side of the head where the sc tensioner is. take the tensioner off, then bolt it on to one of them 2 other bolts. you may see a out line of the eye loop on the head or bracket.
  8. #8 Re: No fire after LIM gasket work...
    Sep 2011
    Canada
    Alright thanks! I hope that fixes it! I'll be at it tonight!
    Here's some pics of the work so far:
    Cleaning the Lower Intake in the parts washer:
    My lovely wife cleaning my valve covers:
    New aluminum gaskets:
  9. #9 Re: No fire after LIM gasket work...
    did you rtv the gaskets to the lim?
    they lay on the head with them 2 pins, same for the rubber on the front and back side, the pins goi in the holes in the block.
    dab rtv in the 4 corners before any gaskets are in, then put the rubber ends on, then the metal lim gasket, then a dab in all 4 corners again. drop the lim on.
    other then the dab of rtv in the corners, they go in dry.
  10. #10 Re: No fire after LIM gasket work...
    Banned
    Apr 2013
    Mesa,AZ
    ^ What he said
  11. #11 Re: No fire after LIM gasket work...
    Sep 2011
    Canada
    Yup I did that. I just placed the gaskets on the intake for the pic!
  12. #12 Re: No fire after LIM gasket work...
    you didt rtv them in tho right? that could be your problem.
  13. #13 Re: No fire after LIM gasket work...
    Sep 2011
    Canada
    Not sure what you mean by rtv? I did place the left and right gaskets in the holes then used silicone on the corners when I put the lim in place on the aluminum side gaskets.
  14. #14 Re: No fire after LIM gasket work...
    ok, so the metal gaskets went in dry? this one pic looks like its got rtv smeared on it.
  15. #15 Re: No fire after LIM gasket work...
    Sep 2011
    Canada
    That's a metal gasket and yes it has rtv on it. I did the same with the other 2 gaskets when I put them in the holes too.
  16. #16 Re: No fire after LIM gasket work...
    it should be installed dry, no rtv.
    can you post a vid of it trying to start? maybe its sucking air form the lim if it didn't seat right.
  17. #17 Re: No fire after LIM gasket work...
    Banned
    Apr 2013
    Mesa,AZ
    My guess is fix that one ground and it will be good to go. A bad ground can stop it from running.
  18. #18 Re: No fire after LIM gasket work...
    Sep 2011
    Canada
    My issue right now is I have no spark so I'm going to try changing the place for ground first. I put a thin layer of silicone like there already was when I took the old gaskets out. I'll do a vacuum test once I get it started. Unfortunately I will only get to it tonight.
  19. #19 Re: No fire after LIM gasket work...
    yeah move that ground wire and see how it runs.
  20. #20 Re: No fire after LIM gasket work...
    Yup my vote would be check the ground wire that's around the coil pack.. Check the voltage if needed. I've had the little wire break on me a time or two and stopped the car from starting.
    04 Comp G.
  1. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
  2. 2007 GXP No gears work and reverse lights dont work
    By MikeJenkins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2012, 06:05 AM
  3. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  4. Electrical issues on 98 gtp, Half electronics work most dont work
    By Eric Krawczak in forum General Tech Discussion
    Last Post: 04-30-2012, 10:06 AM
  5. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
