Thread: What gaskets to use on Gen V with a Gen 3 SSIC
Results 1 to 13 of 13
  1. #1 What gaskets to use on Gen V with a Gen 3 SSIC
    Donating Users timboku's Avatar
    Montgomery, IL
    Alright,
    Got a gen V cheap. Going to do the swap. Got the Gen 3 off. I have a gen 3 ssic. I know its not the best but I am waiting for guy who makes the intercoolers on the this this site to get the machine up and running so will get one of those when its back up. HOPE SOON>...lol.
    Anyway, should I change my LIM to the gen V one, or just keep my GEN 3 LIM on it on for now (Since I just put new mobile one in a few weeks ago dont want to go to waste with replacing the LIM). The SSIC is a Gen 3 so not sure it will make much difference. I currently have a GEN 3 gasket between the LIM and SSIC. Would I be fine leaving that set up and just run a GEN V gasket on top of the SSIC with the GEN V on top of that for now? Or would it be better to change the LIM and all the gaskets to GEN V???
    The SSIC looks like it would cover the openings of the Gen V LIM so not sure what the difference is between a Gen 3 SSIC and a GEN V SSIC. Cant find anyone with pics of both.
    Sorry this is long but anyhelp would be great.
    Thanks!
  2. #2 Re: What gaskets to use on Gen V with a Gen 3 SSIC
    Willoughby, Ohio
    you will need the gen V lim, gen V core, and Gen V gaskets with the gen V blower as they are different. the gen III lim can be machined I believe but if you have a lim on the way might be better to wait
  3. #3 Re: What gaskets to use on Gen V with a Gen 3 SSIC
    Just slap the gen v on in the gen 3 place and rock it
  4. #4 Re: What gaskets to use on Gen V with a Gen 3 SSIC
    Montgomery, IL
    Yep..thats what I did...except zzp gave me 2 wrong bolts when I ordered the gen v set...ugh cant wait to here how it whines.
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  5. #5 Re: What gaskets to use on Gen V with a Gen 3 SSIC
    Mercer, Pa
    Gen 3 and 5 LIM's are the same casting. The GEN 5 lim has a bigger hole (approx. 1") for the supercharger air. You can bolt it in no problem.
    You can not bolt a GEN 3 supercharger to a gen 5 lim, it will leak!!!!
  6. #6 Re: What gaskets to use on Gen V with a Gen 3 SSIC
    hangover park IL
    you will use a gen5 upper and a gen3 lower gasket
    ~James~ Psychotic Gearhead
  7. #7 Re: What gaskets to use on Gen V with a Gen 3 SSIC
    Montgomery, IL
    Thanks for the responses..I used gen 3 liwer snd gen 5 upper...sseilmnop looking to get a full size ic from you when you are back up and running!
  8. #8 Re: What gaskets to use on Gen V with a Gen 3 SSIC
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by sseilmnop View Post
    False ..... I have done it and NOT have it leak. But we used RTV not gaskets.
    2011 F-150 Yote powered
  9. #9 What gaskets to use on Gen V with a Gen 3 SSIC
    Mercer, Pa
    Quote Originally Posted by timboku View Post
    With enough RTV I guess it could be done. Will not seal with a gasket because the hole in the intake goes slightly under the snout.
  10. #10 Re: What gaskets to use on Gen V with a Gen 3 SSIC
    Jun 2011
    I've seen a LOT of guys use the Gen3 IC core with a GenV.
  11. #11 Re: What gaskets to use on Gen V with a Gen 3 SSIC
    Jun 2011
    There's a buddy of mines car. GenV with Gen3 core and Lim
  12. #12 Re: What gaskets to use on Gen V with a Gen 3 SSIC
    Montgomery, IL
    Yup set it all.up..works great besides that zzp sent me wrong bolts and apparently my fuel pump is going.out..love the whine of the gen v!
  13. #13 Re: What gaskets to use on Gen V with a Gen 3 SSIC
    Montgomery, IL
    Heres mine
  1. Ssic
    By boothe in forum Wanted To Buy - Parts
    Last Post: 02-29-2012, 10:55 PM
  2. SSIC and LIM
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2009, 07:48 PM
