Thread: Random misfires only at idle
Results 1 to 15 of 15
  1. #1 Random misfires only at idle
    Mar 2012
    South Beloit, IL
    I figured I would start a new thread for this since the old thread is irrelevant.
    OK. So I did a camshaft swap on my car. Did the VS cam with SD Headers and a 3.4" pulley. I also replaced the front cover gasket, SC gasket, and LIM gaskets with the aluminum ones. New Autolite 104 plugs and OEM wires. I have not tuned the car.
    When I first start the car, the misfires aren't bad, hardly even noticeable if any. Once it warms up, they start to become much more apparent, I can hear the car stumbling. Using Torque, I got the number of misfires for each cylinder, and cylinders 3 and 5 have by far the most misfires. 1 and 4 misfire very seldom. 2 and 6 not at all. Codes P0300 and P0305 (Random misfires and Cylinder #5 misfire) get set eventually. However, when the car moves, I get no misfires at all that I can account for. My OBDII software does not pick any up, the power is smooth and plentiful, and it doesn't set any codes.
    Things it could be due to? :
    Because the SD headers relocated the front O2 port, I did do a chop job on extending my O2 sensor, but it reads a full 0.1 to 0.9 volt range.
    The car sat for 4 1/2 months and the fuel filter was changed 30,000+ miles ago. Possibly bad fuel? But again, the car has great power.
    Leaking LIM gasket? God I hope not..that would be depressing.
    Solutions attempted:
    I tried to re-seat the injectors with lubing the o-rings and a rubber mallet, but that didn't seem to help.
    Ideas:
    Change the fuel filter
    Do a compression test to check for just that
    Fuel pressure test
    Injector cleaner
    Any information would be extremely helpful. Thanks.
  2. #2 Re: Random misfires only at idle
    What plugs are you running and what gap?
    Reduce the gap to .050 if the gap is bigger.
  3. #3 Re: Random misfires only at idle
    Mar 2012
    South Beloit, IL
    Autolite 104s. I haven't checked the gap, but I will gap them as soon as I head home.
  4. #4 Re: Random misfires only at idle
    Mar 2012
    South Beloit, IL
    Question. Could a faulty front O2 sensor cause misfires at idle? Here's my reasoning:
    Because I got SD Headers, I had to extend my front O2 sensor. Instead of being intelligent and buying an extension from ZZP, I thought i would solder in an extension myself. Well, the wires are steel, so soldering wasn't gonna happen. Instead, I twisted the wire pairs as tight as I could, lubed them up with some dilectric grease on the outside, and heat shrinked them shut. Yes, rigged as ****.
    Now I am thinking the O2 sensor is giving an artificially low reading because of the added line resistance, which is telling the PCM that the car is running rich. As a result, the car is leaning out the mixture, causing misfires at idle when the car is in open loop. When I drive, the car goes to closed loop, disregarding the O2 sensor. As a result, absolutely no misfires.
    I will try replacing the O2 sensor next if misfires at idle can be a result of a faulty one.
  5. #5 Re: Random misfires only at idle
    re do the 02 extension with wire, solder and shrink tubes. a solid wire and no solder at all is not gonna work well.
  6. #6 Re: Random misfires only at idle
    Mar 2012
    South Beloit, IL
    So the added resistance could be a culprit of misfires at idle? I'll go ahead and re-do it.
    Also, if there was one gauge you could buy, what would it be? I'm thinking buying a wideband O2 or an AFR controller (until I have tuning software).
  7. #7 Re: Random misfires only at idle
    the whole way its connected is a problem. like you said rigged lol lets un rig it and make it right, see what happens.
    id try to match the wire size too.
  8. #8 Re: Random misfires only at idle
    Mar 2012
    South Beloit, IL
    Unfortunately, unrigging it is not that simple. I am fairly experienced in electronics and soldering, but steel wires do not accept solder at all, even with flux. The only way to un-rig it would be to buy another one and buy an extension. Got any ideas on bonding steel and copper wires together?
  9. #9 Re: Random misfires only at idle
    butt connectors but use the crimp tool so its good and tight, then add shrink tube over it. make sure your using the right size butt connector for the wires too.
    if you can tug on the connection and it pulls a part it was no good to start with. good test before you shrink tube it.
  10. #10 Re: Random misfires only at idle
    Mar 2012
    South Beloit, IL
    Wow. I wish I had known about those, they look like they'll work no problem. Thanks for the help, I'll return with results later!
    P.s. - Did you happen to see my question about a second gauge?
  11. #11 Re: Random misfires only at idle
    what second gauge?
  12. #12 Re: Random misfires only at idle
    Mar 2012
    South Beloit, IL
    what second gauge?
  13. #13 Re: Random misfires only at idle
    aeroforce would be the best first gauge to get.
  14. #14 Re: Random misfires only at idle
    Mar 2012
    South Beloit, IL
    Okay. Does this gauge make Torque Pro look like a fool? Lol.
  15. #15 Re: Random misfires only at idle
    its more accurate by far id think for the live data.
  1. Random misfires........
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2013, 08:21 PM
  2. p0300 random misfires
    Last Post: 04-29-2013, 09:44 PM
  3. Random misfires
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2012, 07:39 PM
  4. Bad rear 02 sensor and random misfires. Can runs just fine.
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2009, 04:41 PM
  5. random misfires
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 09-14-2009, 06:26 AM
