Thread: Bottom end power
Results 1 to 20 of 28
  1. #1 Bottom end power
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    Lets see.. I'm having an issue.. I have a l32 swap into an 03 monte ss.. Mids: headers 3.4 pulley 180tstat tuned by intense 42lbs injectors... 1.8 rockers no cat..... The take off is slow as piss water but top end is strong.... It won't crack a tire....which is weird stock gtps can burn 18s...soo.. Ideas?
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  2. #2 Re: Bottom end power
  3. #3 Re: Bottom end power
    brunswick
    Got aeroforce.. Don't know what to look for
  4. #4 Re: Bottom end power
    are you running the monte trans? Maybe torque managament taking over.
  5. #5 Re: Bottom end power
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Possible sc belt slip? Did you get a smaller belt? Did you get a mail in tune from Intense or a dyno tune?
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  6. #6 Re: Bottom end power
    brunswick
    Custom mail by intense and 04 trans as well and yes smaller belt on car too
  7. #7 Re: Bottom end power
    see what your timing is like when you take off.
  8. #8 Re: Bottom end power
    Florida
    ^ Check your timing at launch, and also see if it accelerates better if you roll into the throttle, or just mash it.
  9. #9 Re: Bottom end power
    Feb 2009
    flintnasty MI
    if you have sorta good tires i would expect this.. headers kill tons of power under the curve and you really are not doing much in terms of mods outside of a 3.4 pulley, which isnt much.
  10. #10 Re: Bottom end power
    brunswick
    I do know timing is stock in pcm and should I put the 3.3 on
  11. #11 Re: Bottom end power
    brunswick
    The car runs better when I ease into it the floor vs just flooring.... and should I put .3 on
  12. #12 Re: Bottom end power
    Florida
    Are you seeing any knock with the 3.4??
    headers do move the powerband up some, but you should still be putting enough torque down to spin the tires a bit.
  13. #13 Re: Bottom end power
    brunswick
    No k.r with.4 on and I can get some chirping while turning but as far as gunning nothing.... even building up around 2500 rpm it seems to boggsit feels like something holding car back until it finally reace 3k then clears up and hauls ass... only in 1st gear
  14. #14 Re: Bottom end power
    brunswick
    New filter and fluid along with lucas in trans............ tb cleaned and working new plugs wires air and fuel filters and air filters..... also when in park/nutural it revs clean when engine under load it seems to be held back
  15. #15 Re: Bottom end power
    See what your timing is when it's doing it
  16. #16 Re: Bottom end power
    brunswick
    Whats timing labled as on aeroforce
  17. #17 Re: Bottom end power
    brunswick
    Ignition advance?
  18. #18 Re: Bottom end power
    Jul 2012
    Chicago
    Yup!
    -Carl
  19. #19 Re: Bottom end power
    brunswick
    Idle is 22.5 wot is 11
  20. #20 Re: Bottom end power
    that's disgustingly low. you're getting KR or your tune is whack.
  1. Replacing L67 bottom end for L26 bottom end
    By OcalaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2013, 06:05 PM
  2. bottom swap, or how i learned to rebuild the bottom end completely
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:37 AM
  3. bottom end
    By rodman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2008, 11:01 AM
