Thread: Car dies when starting in cold weather?
Results 1 to 20 of 24
  1. #1 Car dies when starting in cold weather?
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    So for thr record this is the first time this car has has failed to start in this sh*t weather. It was 5° tonight and I was tried to remote start the car and thought nothing about I went outside about 5minutes later and its off. Thought I must have been out of range or something. I hop in start her up idles kinda high for a few seconds and they dies. I let it sit for a second and tried it again giving it some throttle. Strangely and this is was fine. Not sure why it died. Crappy gas? Cold Weather ... ? Also I have been noticing this strange whinning/sucking/howling (when idling or under like throttle) its hard to describe. Probably just the effects of the cold weather but I have yet to ever have a car act this way so im just concerned thanks for you input in advance
    FYI it drives just fine. I drove for over 2hours prior to taking that video.
    Video :
    http://www.youtube.com/watch?v=qWVCI...cc&app=desktop
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  2. #2 Re: Car dies when starting in cold weather?
    Nov 2013
    Des Moines, IA
    Not sure if the problems are related
    2007GPGTSC
    " sad thing is "
  3. #3 Re: Car dies when starting in cold weather?
    Aug 2013
    McDonald PA
    That's a weird ass sound. I have no clue what that could bw
  4. #4 Re: Car dies when starting in cold weather?
    Nov 2013
    Des Moines, IA
    Yeah thats what I thought sounds like a little turbo whistle lol
    2007GPGTSC
    " sad thing is "
  5. #5 Re: Car dies when starting in cold weather?
    Aug 2013
    McDonald PA
    Sounds like your intake with some sort of belt or pulley going bad because if the car dies that means it would not be getting power or spin from the alternator
  6. #6 Re: Car dies when starting in cold weather?
    that sounds like a frozen power steering pump/thick fluid. if it went away soon after it started thats what it is. mine was angry the other day in 4 deg's it made some whining and went away as i softly rocked the wheel back and forth a little bit.
    as far as the stalling, the auto start thought it kicked over, but it failed. it takes a longer crank to fire these cars up in the ice cold.
  7. #7 Re: Car dies when starting in cold weather?
    Aug 2013
    McDonald PA
    Now that I think of it. That's what my car did when it was -33 I should have just went out and started it but some how she cranked over with the remote
  8. #8 Re: Car dies when starting in cold weather?
    Nov 2013
    Des Moines, IA
    I just replaced the pump like 2months ago I cracked the cap and I can see the flow. I looked up some stuff could it be a bad idler pulley?
    2007GPGTSC
    " sad thing is "
  9. #9 Re: Car dies when starting in cold weather?
    Nov 2013
    Des Moines, IA
    Its just funny how it just started since it was -20
    2007GPGTSC
    " sad thing is "
  10. #10 Re: Car dies when starting in cold weather?
    did the whine go away after a little while. like with in minutes? if so, see my last post up there ^^^^^^^^
  11. #11 Re: Car dies when starting in cold weather?
    Nov 2013
    Des Moines, IA
    No I drove for over 2 hours I think i put that in the original post but no biggy it never goes away unless the motor is revved to the point where you cant hear it
    2007GPGTSC
    " sad thing is "
  12. #12 Re: Car dies when starting in cold weather?
    take the belt off, then start the engine, if its gone its something on the front of the engine is to blame.
    hows the power steering? stiff or it feel normal?
  13. #13 Re: Car dies when starting in cold weather?
    Nov 2013
    Des Moines, IA
    Feels fine no changes. No stiffness ect
    2007GPGTSC
    " sad thing is "
  14. #14 Re: Car dies when starting in cold weather?
    pop the belt off, spin the pulleys by hand see if one wobbles or dont turn smooth. then fire it up with no belt on to make sure its not something else.
  15. #15 Re: Car dies when starting in cold weather?
    Nov 2013
    Des Moines, IA
    I will do it this weekend. Dont have time right this second but I made a better video for reference its definitely not coming from the PS pump coming from one of the pullies up front from the sound
    2007GPGTSC
    " sad thing is "
  16. #16 Re: Car dies when starting in cold weather?
    with the car running, (this aint safe. do at your own risk) reach in and put a finger on the bolt holding the tensioner, and the idler pulleys. if its bad you will feel it grinding via your finger tip. you'll notice it clearly if the other pulley is smooth feeling. just be careful you dont loose a finger.
  17. #17 Re: Car dies when starting in cold weather?
    Nov 2013
    Des Moines, IA
    Haha I will do that tomorrow after work its pretty dark out and id rather not lose a finger
    Heres the vid link :
    https://www.youtube.com/watch?v=mJqqJHXETjM
    2007GPGTSC
    " sad thing is "
  18. #18 Re: Car dies when starting in cold weather?
    Nov 2013
    Des Moines, IA
    Also not sure what the hell my traction control was doing probably the 2inch thick ice on the ground ... not sure why it said it turned off ? Haha
    2007GPGTSC
    " sad thing is "
  19. #19 Re: Car dies when starting in cold weather?
    that metallic squeal, sounds like a bad idler pulley. check it asap. when it blows, it blows up good, when you toss a belt it can break other stuff for you.
  20. #20 Re: Car dies when starting in cold weather?
    Nov 2013
    Des Moines, IA
    I believe that is the alternator making noise. Its unrelated to the humming coming from up from . Idk if its normal but my other 04 gp did the same
    2007GPGTSC
    " sad thing is "
  1. Just some cold weather pulls in the GP
    By CapnBreakAlot in forum Track Sessions and Kills
    Last Post: 11-19-2013, 05:51 PM
  2. cold weather brings cold engine
    By Garrett Mofford in forum Engine
    Last Post: 12-31-2012, 08:45 PM
  3. Cold weather starting!!
    By Madness in forum General Tech Discussion
    Last Post: 02-28-2011, 02:55 PM
  4. Cold Weather and Speakers
    By I800C0LLECT in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2011, 06:31 AM
  5. Washing Your Car in Cold Weather
    By Traeger2591 in forum Off Topic Discussion
    Last Post: 01-12-2010, 11:06 AM
