Thread: No start after engine put back together
Results 1 to 20 of 35
  1. #1 No start after engine put back together
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    Mods in sig, turned engine over a few times to build oil pressure, then primed fuel lines 5 times, started car, it started up was kind of bouncing up and down at 1k rpms, then went down to 6, then 4 and then idled there for a bit, then turned off. now it wont start back up.
    i figure im gonna start with a compression test and go from there, also check to see if the sensors on the N* tb are reading.
    is there anything special im supposed to do for the Idle Air Control on a N* or PCV?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: No start after engine put back together
    Mar 2012
    Dallas
    also while it was idling, it sounded like it was misfiring. i really hope my pushrods are not too long, compression test will tell me that. they seemed fine. maybe its something simple as spark plug wires not in the right spot or something, but would that make the car to stall and cause no start?
  3. #3 Re: No start after engine put back together
    GT Level Member RegalGS98s's Avatar
    NJ
    How longs the car been sitting? I'm thinking fuel starvation. Either pull the fuel line off and turn the key to see if the pump is getting fuel there or starting fluid in the intake which might be a little more harsh and bad on the supercharger's rotor coating, but a quick check. Fuel filter could of clogged up if it sat for a while.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  4. #4 Re: No start after engine put back together
    Mar 2012
    Dallas
    well i primed pump 5 times before start.
  5. #5 Re: No start after engine put back together
    NJ
    Quote Originally Posted by TEK310 View Post
    Right so some fuel could of got through and then clogged. If the car sits for a day and then you're able to get it to start, then it might have something to do with the pushrod length and having it sit for a day let the lifters bleed out, but I'd say check for fuel. Do you still hear the fuel pump run when you turn the key?
  6. #6 Re: No start after engine put back together
    Mar 2012
    Dallas
    im gonna be really upset if its pushrods
  7. #7 Re: No start after engine put back together
    NJ
    Yeah so start with fuel and hope for the best with a clogged fuel filter and/or injectors. Again how long did the car sit?
  8. #8 Re: No start after engine put back together
    Mar 2012
    Dallas
    um since dec 24
  9. #9 Re: No start after engine put back together
    NJ
    um since dec 24
    Shouldn't be an issue then, but still would check. Then would pull out the compression tester.
  10. #10 Re: No start after engine put back together
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    This site has turned me into a carpochondriac. Everytime someone has something wrong with their car I replace it on mine. lol. I just ordered both crankshaft sensors a camshaft sensor and a compression tester. Thought I was done under the hood. At this rate I'll never get this car finished, but man,I am learning so much from you guys.
  11. #11 Re: No start after engine put back together
    Banned
    Jan 2013
    maryland
    Man this sounds my situation.. I would check fuel for sure my car sat for a couple days before I cranked it and it turned out I had to bend tab 85 on my fuel relay to keep it on.. hows your oil? Any sludge? Any Coolant in the throttle body?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  12. #12 Re: No start after engine put back together
    Let the car cool.. see if it'll start up again. If so, when your lifters are pumping up..they are holding cylinders open. That happened to Sexman a while back on his build.
    You could also have an air bubble in the system that is overheating the engine and allowing it to bind. This is usually not a problem if you aren't revving etc and it stalls.
    Nothing special with the IAC. PCV.. yes you need to reroute it to the TB. If you have an adapter plate on their..likely it's blocked.
  13. #13 Re: No start after engine put back together
    Mar 2012
    Dallas
    how do I route it to the tb? also couldn't run engine long enough to cause a heating issue. I will likely need to buy a set of shorter pushrods....
  14. #14 Re: No start after engine put back together
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    It kinda sounds like a massive vacuum leak
    2001 sliver gtp her name is Reagan
  15. #15 Re: No start after engine put back together
    NJ
    Did you check for fuel yet or try to start it again since letting it cool?
  16. #16 Re: No start after engine put back together
    Mar 2012
    Dallas
    not yet. at work will check when I get off
  17. #17 Re: No start after engine put back together
    Mar 2012
    Dallas
    so far, i found coolant in my intake leaking from between the adaptor plate and my supercharger getting sucked into inlet. gotta figure out a way to seal that, maybe some quicksteel. will get the stuff to fix it tomorrow and go from there.
    would that be enough to stall out the engine, i dont think it ingested enough coolant to fill the cylinders
  18. #18 Re: No start after engine put back together
    NJ
    so far, i found coolant in my intake leaking from between the adaptor plate and my supercharger getting sucked into inlet. gotta figure out a way to seal that, maybe some quicksteel. will get the stuff to fix it tomorrow and go from there. would that be enough to stall out the engine, i dont think it ingested enough coolant to fill the cylinders
    Coolant doesn't have to fill the cylinders. If the spark plugs get wet with coolant, they won't spark and cause misfires. That will cause the car not to start if enough of them got wet. My Expedition had a misfire, so I pulled that sparkplug. Found it was wet with coolant so fixed the coolant leak issue for that cylinder and no misfires now. Spark, gas and compression are needed with the air. If one is missing, engine won't run.
  19. #19 Re: No start after engine put back together
    Banned
    Jan 2013
    maryland
    Same issues with mine bro same issues
  20. #20 Re: No start after engine put back together
    Mar 2012
    Dallas
    did you fix it?
  1. oil on back of engine
    By schmitt in forum General Tech Discussion
    Last Post: 06-03-2011, 12:39 PM
  2. 97 GP GT ignition key wont turn back after start...
    By AREED in forum General Tech Discussion
    Last Post: 12-23-2010, 09:07 AM
  3. So, putting engine back together after cam install
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 08:25 AM
  4. car wont start after top end put back on.
    By glanzergtx in forum General Tech Discussion
    Last Post: 10-19-2009, 10:49 PM
  5. engine bay %99 back together
    By Preotic in forum Visual/Body Modifications
    Last Post: 03-11-2008, 09:05 PM
