Thread: No start after engine put back together
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: No start after engine put back together
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    so your car is also sucking in coolant from the throttlebody? im gonna have to pull my spark plugs and turn the engine over and shoot out any coolant that is fouling the mixture, but i think this is only part of my problem. i feel like my pushrods are too long as well.
    we will see after i get everything put back together. im gonna fill the coolant holes with quicksteel.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #22 Re: No start after engine put back together
    Banned
    Jan 2013
    maryland
    Yea my car sucked coolant in the throttle body and a little in the supercharger but I'm puttin new coolant in soon but it has to be my coils man Im feelin like that's the issue fuel pump primes everytime I crank it but it seems like you need to go back to stock for pushrods any reason why you got aftermarket ones?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  3. #23 Re: No start after engine put back together
    Mar 2012
    Dallas
    they are stock size, just lightweight, but i got ls7 lifter that dont like as much preload. i need shorter ones
  4. #24 Re: No start after engine put back together
    GT Level Member RegalGS98s's Avatar
    NJ
    Quote Originally Posted by TEK310 View Post
    so far, i found coolant in my intake leaking from between the adaptor plate and my supercharger getting sucked into inlet. gotta figure out a way to seal that, maybe some quicksteel. will get the stuff to fix it tomorrow and go from there. would that be enough to stall out the engine, i dont think it ingested enough coolant to fill the cylinders
    Coolant doesn't have to fill the cylinders. If the spark plugs get wet with coolant, they won't spark and cause misfires. That will cause the car not to start if enough of them got wet. My Expedition had a misfire, so I pulled that sparkplug. Found it was wet with coolant so fixed the coolant leak issue for that cylinder and no misfires now. Spark, gas and compression are needed with the air. If one is missing, engine won't run.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  5. #25 Re: No start after engine put back together
    Mar 2012
    Dallas
    okay. I really hope this fixes my problem. will give a update after I get off work and fill the coolant holes and slap it back together.
    it didn't sound like valves where open when it was running. I have heard that sound before. puff puff puff sound
  6. #26 Re: No start after engine put back together
    NJ
    okay. I really hope this fixes my problem. will give a update after I get off work and fill the coolant holes and slap it back together. it didn't sound like valves where open when it was running. I have heard that sound before. puff puff puff sound
    Yeah hopefully. Think you were looking at it complicated like I usually do when you just had to step back to the basics.
  7. #27 Re: No start after engine put back together
    Mar 2012
    Dallas
    gotta take of superharger to fill coolant holes, mind as well do pushrods too. will happen saturday all day
  8. #28 Re: No start after engine put back together
    Banned
    Jan 2013
    maryland
    I hear ya same here
  9. #29 Re: No start after engine put back together
    Mar 2012
    Dallas
    got everything together and it started up. but my throttle cable was kinked a while back and it won't work with this throttle body. its too short, so I have to replace that and I broke my throttle pedal when I was thrhing to fix it.
    my lower intake manifold had a pool of coolant in it. all my spark plugs were soaked in coolant. got my pushrods in and everything. got some stuff to wire out. think I have a small vac leak. I hear a whistling sound
  10. #30 Re: No start after engine put back together
    NJ
    So it stays running now then? If so cool. Coolant on the spark plugs will definitely do it.
  11. #31 Re: No start after engine put back together
    Mar 2012
    Dallas
    yup stays running.
  12. #32 Re: No start after engine put back together
    The Boss Iceman6669's Avatar
    Jun 2011
    So you DID in fact need shorter pushrods?
    2011 F-150 Yote powered
  13. #33 Re: No start after engine put back together
    Mar 2012
    Dallas
    I'm pretty sure the coolant was the main contributing factor of the stalling and no start. but I put the pushrods in just for a piece of mind.
    there was a lot of coolant in the intake.
  14. #34 Re: No start after engine put back together
    Mar 2012
    Dallas
    now im having problems like before, when my IAC connector came loose, gotta keep gas pedal down some to keep it from dieing. and it cuts out bad when trying to accelerate.
    anyone fimiliar with the IAC setup on the Northstar setup with the zzp adaptor plate?
  15. #35 Re: No start after engine put back together
    Mar 2012
    Dallas
    what should fuel pressure be at idle?
  1. oil on back of engine
    By schmitt in forum General Tech Discussion
    Last Post: 06-03-2011, 12:39 PM
  2. 97 GP GT ignition key wont turn back after start...
    By AREED in forum General Tech Discussion
    Last Post: 12-23-2010, 09:07 AM
  3. So, putting engine back together after cam install
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 08:25 AM
  4. car wont start after top end put back on.
    By glanzergtx in forum General Tech Discussion
    Last Post: 10-19-2009, 10:49 PM
  5. engine bay %99 back together
    By Preotic in forum Visual/Body Modifications
    Last Post: 03-11-2008, 09:05 PM
