Thread: A problem that only shows up at normal temp, warmed up
Results 1 to 20 of 30
  1. #1 A problem that only shows up at normal temp, warmed up
    Dec 2013
    Louisville
    I start my 99 gtp (completely stock other then cat' has been cut off)
    Runs fine, pulls decent, Only making 1/2 boost according to digial gauge, but feeling that's the intake manifold gaskets. now everything runs find till it's warmed up if i have to drive in stop light traffic it starts to stumble,backfire, and die and sounds like it's missing bad.
    Now if I shut it off and wait 5 mins runs find no problem till it happens again. now if I get on the highway and drive 60+ it never does it.
    any ideas (owner said it had a cloged cat so they cut it off)
  2. #2 Re: A problem that only shows up at normal temp, warmed up
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    1/2 boost sounds like the BBV took a dump on you. (The electronic solenoid below the vacuum canister on the side of your SC.). Or a vacuum line is cracked or come unplugged.
    As far as the running issues, I would start simple and clean the MAF. make SURE it is completely dry before you reinstall.
    Sent from Not so smart smartphone
  3. #3 Re: A problem that only shows up at normal temp, warmed up
    so being it has no cat the cel is on already right? so get it scanned see what codes its got.
    this could be as simple as a it needs a tune up. if its random misfires
  4. #4 Re: A problem that only shows up at normal temp, warmed up
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Possibly stuck open EGR valve
    I went NA when a whore left -$300 in my bank account.
  5. #5 Re: A problem that only shows up at normal temp, warmed up
    Dec 2013
    Louisville
    No codes.: /
  6. #6 Re: A problem that only shows up at normal temp, warmed up
    Jul 2013
    Summertown Tn
    Check the vacuum line, the BBV and clean the MAF.
  7. #7 Re: A problem that only shows up at normal temp, warmed up
    Dec 2013
    Louisville
    Swapped coil packs, and ignition module, ignition module was atved to the mount -__-
    Now I make no boost on the gauge, pulls good but still gets warm and starts missing like holy ****
    Swapping maf for a good one
  8. #8 Re: A problem that only shows up at normal temp, warmed up
    if its misfiring that bad there should be a code for it. maybe stored so the lights not on. id get it re scanned.
    what the word on that tune up? ever do one?
  9. #9 Re: A problem that only shows up at normal temp, warmed up
    Dec 2013
    Louisville
    Nothing. Maf don' help, tune up still no better runs smoother until its warm
  10. #10 Re: A problem that only shows up at normal temp, warmed up
    have you done one since you owned the car? a tune up that is? whats the miles?
    old plugs and wires can do exactly what your describing.
  11. #11 Re: A problem that only shows up at normal temp, warmed up
    Dec 2013
    Louisville
    Just today
  12. #12 Re: A problem that only shows up at normal temp, warmed up
    what plugs did you put in?
  13. #13 Re: A problem that only shows up at normal temp, warmed up
    Dec 2013
    Louisville
    Al605
  14. #14 Re: A problem that only shows up at normal temp, warmed up
    are those the double platinum plugs? if so toss them and go get some iridium plugs. these cars dont like the plats one bit.
  15. #15 Re: A problem that only shows up at normal temp, warmed up
    Dec 2013
    Louisville
    I was able to pull as code now. Boost solenoid, low maf signal, and 3x reference circuit
    The Wire harness is a bit rough. For the crank,cam,and ign
  16. #16 Re: A problem that only shows up at normal temp, warmed up
    Dec 2013
    Louisville
    No they are what the write up on how to safely mod your 3800sc
  17. #17 Re: A problem that only shows up at normal temp, warmed up
    the maf, check the wires to it, if you see any cracks in the wires near the plug or down the wire, it can cause the low circuit code.
    new pig tails are cheap. around 10 bucks.
  18. #18 Re: A problem that only shows up at normal temp, warmed up
    GT Level Member m17davis's Avatar
    Orland Park, IL
    I've been running at about 4.5 psi since I bought my car about 6 years ago. About a week ago I found out I was at about half boost I should be at. 10 minutes ago I replaced the BBV solenoid with the one on my extra gen3. Now im at 10 psi of boost.
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  19. #19 Re: A problem that only shows up at normal temp, warmed up
    Dec 2013
    Louisville
    Swaped out the wires nothing, runs good then goes full retard 15-20mins later. Wait 5-10 mins runs fine for another 15-20mins before going full retard again
  20. #20 Re: A problem that only shows up at normal temp, warmed up
    Dec 2013
    Louisville
    Update, when it starts acting up the bbv opens and closes over and over and over, smells pig rich,and sounds like a bad miss on 2 or more cyls
    I'll try to get a video of it tonight
  1. What's a normal trans temp for the 4T65E?
    By Vinson clark in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-31-2012, 08:32 PM
  2. Normal transmission temp for GXP?
    By Snik225 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-29-2012, 02:20 PM
  3. 3800 Normal Operating Temp
    By 08 198 Champ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2012, 10:52 AM
  4. Normal coolant temp?
    By nboylie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-07-2009, 08:46 PM
  5. What temp should a 2004 GTP run at when warmed up?
    By Edmonchuck in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2008, 11:34 PM
