Thread: Thermostat Questions
Results 1 to 12 of 12
  1. #1 Thermostat Questions
    Nov 2008
    wichita
    I was about to Order this SLP Performance Parts Thermostats when I started to think what makes this diiferent from Duralast / Thermostat Note: 180 degrees
    Alternate temperature
    Same temp different price, Is there any performance difference in them? also is there a right up on changing your thermostat
  2. #2 Re: Thermostat Questions
    TDCRacing
    Guest
    Ok everyone let's answer his actual question. And not answer the question of will a thermostat bennefit him any.LOL
    There is no difference between the two. Some claim to flow more and that may be the case but usually anything you buy that is aftermarket will outperform OEM....Well,As far as thermostats go anyway.
    Hope that helps.
  3. #3 Re: Thermostat Questions
    PA
    Quote Originally Posted by TDCRacing View Post
    Hope that helps.
    Okay dad!
    Yeah, I never really found much difference in stats. But, what I would recommend, is that you test the t-stat before you install it. I do this to every one before I install it in my car. Just take a pan of water, put the t-stat in it, and start to heat it. I then put a thermometer in the pan of water to watch what the temp is. Any meat or candy thermometer will work fine. Just make sure it opens near the temp it should. If not, take it back. I have gotten ones that open much before the advertised temp, and some that didn't open at all. It only take a minute or two and makes sure you don't have problems later.
    2001 GSE
  4. #4 Re: Thermostat Questions
    TDCRacing
    Guest
    Quote Originally Posted by zef_66 View Post
    okay dad!
    roflmao
  5. #5 Re: Thermostat Questions
    GT Level Member beastin1's Avatar
    south elgin il.
    Quote Originally Posted by Zef_66 View Post
    Okay dad!
    now thats a neat and yet very simple test...great idea....you get a thanks on me
    2002 Galaxy Silver 4dr. GTP...supercharger heaven.
    IM ON IT!!!!!!
  6. #6 Re: Thermostat Questions
    Nov 2008
    wichita
    Hope that helps.
    I dont remember asking if it will help me? but thats whats up going to grab one now. Is putting it on easy, Is there a write up for this
  7. #7 Re: Thermostat Questions
    same same same.
    any over the counter 180* will net you the same results. get it at your local auto parts store.
  8. #8 Re: Thermostat Questions
    TDCRacing
    Guest
    Unscrew the 2 10mm thermostat housing bolt's...take off thermostat....install new gasket if needed....reasemble....
    And no you didnt ask if it would but typically someone will pop up and say It won't help you and the thread will get off subject lol
  9. #9 Re: Thermostat Questions
    Nov 2008
    wichita
    Just got part may put on today, Sure its not going to make me faster lol, But I got my CAI also. Just need time to but them on now
    SO lets see I got my a104s my cia and thermostat. Pulley Downpipe and PCM are next. Question when should I tune PCM I have a local guy that will tune PCM for 100 bucks and then will retune with each mod added for free. My next mod I am getting is a DP, Should I tune PCM after downpipe or after Pulley
  10. #10 Re: Thermostat Questions
    Feb 2008
    If you're going to get free re-tunes, get the tune done now and then again with the new pulley. Otherwise, wait until after the pulley.
  11. #11 Re: Thermostat Questions
    TDCRacing
    Guest
    why are you gettin a pcm if you are getting a tune?
  12. #12 Re: Thermostat Questions
    Nov 2008
    wichita
    No he is going to reprogramm my PCM for 100, then if I make any new Mods he will retune for free
    MOD:AL104s,CAI,DHP TUNED PCM MOD I have not installed:180 Thermostat,3.4 pulley, boost gauge, A/F Ratio Gauge MOD I HAVE NOT ORDERED YET: DP,
  1. thermostat
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2008, 06:38 PM
  2. is my thermostat not opening?
    By nemesis in forum General Tech Discussion
    Last Post: 10-25-2008, 07:16 PM
  3. Thermostat
    By keenan00gtp in forum General Tech Discussion
    Last Post: 10-20-2008, 05:46 PM
  4. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
  5. What Thermostat Should I Get ?
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 07:00 AM
