Thread: what is this? its leaking
Results 1 to 15 of 15
  1. #1 what is this? its leaking
    GT Level Member m17davis's Avatar
    Orland Park, IL
    its looking towards the back of the motor pic taken from right next to the downpipe. I think its the steering.? Thanks for the hello.
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: what is this? its leaking
    Yup, power steering rack. A pretty commom spot for them to leak.
  3. #3 Re: what is this? its leaking
    If it's not leaking to bad i'd let it go until it warms up out.
  4. #4 Re: what is this? its leaking
    Orland Park, IL
    ahh. I always seem to have a leak somewhere. is it an easy fix?
  5. #5 Re: what is this? its leaking
    not really, its a pita the first time out, for 23 bolt job 10 of which are the lug nuts.
    its a good 3 hour job on your back. its not all that hard, your just working in tight quarters.
  6. #6 Re: what is this? its leaking
    Mine was easy took about an hour
  7. #7 Re: what is this? its leaking
    Orland Park, IL
    Did you get yours from a junk yard?
  8. #8 Re: what is this? its leaking
    mine came from a junk yard for 75 bucks.
    make sure your wheels are dead straight, then take it out. once the old one is out put the new one next to it and match up the steering gear nub to as close as the same angle as you can, as well as the lock nuts on the inner tie rods for the outer tie rods. this will keep the alignment close but not perfect. and help get the intermediate shaft back on easier.
    you'll want to get it aligned asap after it put in.
    good time to change the sway bar or its bushings and outer tie rods ( if any of its bad) while doing the rack swap.
  9. #9 Re: what is this? its leaking
    Please take my advise........
    TAKE OUT THE BACK 2 CRADLE BOLTS AND LET IT DOWN A LITTLE TO MAKE MORE ROOM TO GET THE RACK OUT!!!!!!!!
    Your welcome in advance!
    Vet
    Edit no way in hell id use a used rack they are like 125 buck from oreillys! A1 Cardone brand is what ive used twice but not on the same car....................
  10. #10 Re: what is this? its leaking
    Orland Park, IL
    Great advise!! I never would have thought of that! I think I would rather buy a new one.. Hopefully it holds up throughout winter. Thanks guys!
  11. #11 Re: what is this? its leaking
    I would also recommend changing the outer tie rods as well. And that intermediate shaft is kind of a pain.
  12. #12 Re: what is this? its leaking
    St. Louis
    If it's leaking badly, you can refill the PS resevoir with some Lucas PS stop leak instead of normal PS fluid. I got away with this for a good while when my rack started leaking.
    Also, make sure that when you order a new rack that you check to see if you have Magnasteer or not. If you see a 2-wire connector coming off the bottom of the rack near where the steering shaft connects to it, the you have Magnasteer. Also, if you check the sticker on the underside of the trunk lid and see an "NV7" code (IIRC), then this also indicates that you have this option.
  13. #13 Re: what is this? its leaking
    I got my first rack from the jy it was bad and the jy wouldn't return my calls so I went to az and bought a new one
  14. #14 Re: what is this? its leaking
    Orland Park, IL
    where is the sticker on the trunk lid exactly(picture) cause I foamed all of the wholes..
  15. #15 Re: what is this? its leaking
    it should be right on the under side of the trunk.
    to see if you have magna steer just look where you took that pic by the column boot for a wire. if you see a wire leading to a harness its got magna steer.
  1. leaking from where?
    By greengt in forum General Tech Discussion
    Last Post: 05-07-2013, 09:19 AM
  2. Leaking on the top
    By bull40dawg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-24-2012, 07:23 AM
  3. Leaking oil all under car
    By GTLGDP in forum General Tech Discussion
    Last Post: 01-17-2012, 08:15 AM
  4. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
  5. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
