Thread: rough idle still
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: rough idle still
    SE Level Member ssiebor14's Avatar
    May 2013
    Biglerville
    Yeah it did and the gas mileage is absolutely ****. I'm getting 15 to the gallon. I haven't found anyleaks even spraying down the lines
  2. #22 Re: rough idle still
    the fat hose off the TB is like a 1/2 inch round, it loops over the TB to the back of the engine to the evap solenoid. they sell fat vac line, for it, then you push a smaller line inside the fat line then back onto the factory hard plastic line.
    what year is your car? did you delete the rear o2 with the cat delete? did this all start with the cat delete? or soon after it?
  3. #23 Re: rough idle still
    May 2013
    Biglerville
    I did a cat delete. But it was doing this before that. And it's 98
  4. #24 Re: rough idle still
    you have the code it had still? or did you clear it and its of still?
    what did you do with the rear o2? is it still there?
  5. #25 Re: rough idle still
    Arizona
    Have you looked underneath the supercharger, under the snout to make sure you haven blown off the vacuum tee from the LIM ?
  6. #26 Re: rough idle still
    May 2013
    Biglerville
    Rear o2 is still there along with the vacc tee under the snout and I cleared the code it cane back then went off on it's or . Hasn't came back since.
  7. #27 Re: rough idle still
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Quote Originally Posted by ssiebor14 View Post
    What are you fuel trims at idle? Put a fuel gauge on there so see fuel pressure. Also your fuel pump resistor could be on its way out (if so try the relay trick if it wont start back up)
    My GS ran the balls but at idle randomly it would sputter and die along with hard starts. Put a pump in it and so far so good.
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. Rough idle
    By 7point62 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-21-2012, 01:28 PM
  3. Rough Idle
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-01-2010, 10:48 PM
  4. rough idle
    By 02gtpalder in forum General Tech Discussion
    Last Post: 03-07-2010, 12:02 AM
  5. Almost rough idle
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2009, 08:31 PM
