Thread: rattle on accelleration
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: rattle on accelleration
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    I'm thinking cracked or loose flexplate. If it doesn't do it in park or neutral then it has to be tranny related. The torque converter isn't engaged when not in gear. Its also bolted to the flexplate.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  2. #22 Re: rattle on accelleration
    Nov 2008
    tennessee
    ok i will have that checked,,, if thats not it do you have any other suggestions
  3. #23 Re: rattle on accelleration
    Feb 2008
    Houston
    Can't really be anything engine related....where does it sound like the sound is coming from?
  4. #24 Re: rattle on accelleration
    Nov 2008
    tennessee
    well its hard to say u know how noises travel,,, sounds like from near the back side of engine compartment
  5. #25 Re: rattle on accelleration
    Feb 2008
    Houston
    True, check the plate tho. That would be my best guess.
  6. #26 Re: rattle on accelleration
    Nov 2008
    tennessee
    thanks man ! hey u have an aol account ? or just an email so i can keep in touch a quicker way ,,, you have been helpful ,, i would like ti be able to contact you if i have any questions.
  7. #27 Re: rattle on accelleration
    Feb 2008
    Houston
    I don't have AOL, but you can reach me any time of the day at Thomas.Moore.II@gmail.com Good luck!
  8. #28 Re: rattle on accelleration
    Nov 2008
    tennessee
    thanks for the help!!!!
  9. #29 Re: rattle on accelleration
    Feb 2008
    Houston
    Any time, let me know what happens.
  10. #30 Re: rattle on accelleration
    Nov 2008
    tennessee
    thanks i will.
  11. #31 Re: rattle on accelleration
    SE Level Member sonofstroker's Avatar
    Hattiesburg, MS
    Quote Originally Posted by t24moore View Post
    .Possible flexplate issue? Remove your flexplate cover, rotate it to make sure it isn't cracked. Check the bolts also. Is it a metallic rattle or more like a ticking? A bad flex joint can cause a ticking sound when accelerating.
    x2 mine had the same problem and it turned out that two of my convertor bolts were loose.
    97 GTP 2.6 pulley|TOGS|Jimmyc dp catless|103s|DHP|Wizair CAI|180deg tstat|alt rewire|ZZP FP rewire|ZZP S3 IC w/radiator 3|ZZP S4 gen3|lucas 42.5lb injectors|N* TB|LQ4|shift kit|xpcam w/105's|wbody store pulley wrap kit
  1. Help with 2007 Dash Rattle
    By leeklm in forum 04+ Specifics
    Last Post: 01-29-2011, 12:18 AM
  2. Supercharger noise, rattle HELP!
    By Mvfootball1 in forum General Tech Discussion
    Last Post: 08-26-2010, 04:49 PM
  3. Anti Rattle Clips
    By My '08 GXP in forum Brakes/Suspension/Chassis
    Last Post: 11-19-2008, 08:42 PM
  4. Rattle Trap....
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2008, 07:11 PM
  5. Valves rattle
    By johndaysGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 05:46 PM
