Thread: New LIM Gaskets, Now P0300.
Results 1 to 6 of 6
  1. #1 New LIM Gaskets, Now P0300.
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    Just put on fresh LIM gaskets on my 97 GTP and now I got it all back together and it has a rough idle and stalls. When I first start it up it will stall unless I give it some throttle and slowly let off and it settles down to a rough idle. I suspected a vacuum leak and smoked the vacuum lines and around the blower and manifold with no change in rpm. Once in a while the idle will go up to about 2 or 3k and settle back down. Unplugging the MAF did not help and the idle stays consistent at 2-3k rpm with the MAF disconnected. The only CEL I am getting is a P0300. Where should I go from here?
  2. #2 Re: New LIM Gaskets, Now P0300.
    gardner,mass
    Check your firing order and make sure all your vac lines are in the correct location.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #3 Re: New LIM Gaskets, Now P0300.
    Also check the egr tube for cracks
  4. #4 Re: New LIM Gaskets, Now P0300.
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    make sure the injector lower o-rings are seated properly. spray some brake cleaner over the injectors where they seat in the manifold. You will hear an idle change and maybe even hear a sucking sound if they are leaking. Air leaks past the injectors at the manifold will cause lean misfires.
  5. #5 Re: New LIM Gaskets, Now P0300.
    Oct 2013
    Indiana
    if you did the job yourself check under the supercharger and make sure its spotless. just did this and I had the same problem. turns out I didnt clean the up side of the lim good enough
    building a mustang killer one broken bolt at a time.
  6. #6 Re: New LIM Gaskets, Now P0300.
    Dec 2011
    NY
    It ended up being a vacuum leak. I overlooked that I used an l32 supercharger gasket on my L67. Pulled the blower back off and replaced it and all is well
  1. p0300
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2013, 07:27 PM
  2. p0300 missfire
    By falcz420 in forum Engine
    Last Post: 02-11-2012, 02:13 PM
  3. 98 gtp missing...p0300
    By cp93 in forum General Tech Discussion
    Last Post: 02-03-2012, 06:32 AM
  4. p0300 miss
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2012, 04:30 PM
  5. p0300
    By fratzke7 in forum General Tech Discussion
    Last Post: 10-10-2008, 09:19 AM
