Thread: Knock sensors not reporting??
Results 1 to 20 of 23
  1. #1 Knock sensors not reporting??
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    I haven't been able get any knock readout from my sensors the wiring is intact. is there anyway to disable them? I'm not asking to disable I need to know if it was possible that someone has removed the ability to report. it has a tune from the previous owner so idk what has all been done to it. Im in Nashville so if anyone has hp tuners or another way to check it out I'm all ears.
    I ordered a 3.6 pulley and I will no install it until I can read knock
    it has autolite 606's, open cone and a 2.5 dp, 175* thermo and don't ask how or why I have it, it was there when I got it.
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  2. #2 Re: Knock sensors not reporting??
    are you sure it just doesn't have any kr?
  3. #3 Re: Knock sensors not reporting??
    Hit the block where the knock sensor is, or whack the crossover with a hammer and see if some KR shows up on the gauge.
  4. #4 Re: Knock sensors not reporting??
    May 2013
    when i scan it says no data received. i will try that, i'm surprised i didn't think of that...
  5. #5 Re: Knock sensors not reporting??
    What are you trying to read the kr with?
  6. #6 Re: Knock sensors not reporting??
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    I am assuming from his signature that he is using a bluetooth scanner... hmm are the devices (phone,obdII connector) discoverable and paired ? can you read other data, or is it just KR not populating ?
  7. #7 Re: Knock sensors not reporting??
    May 2013
    I can read every sensor on the car with decent accuracy but there is no data logged at all from the scanner. I've used every PID that can be used for my car. for some reason I doubt that I have 0 KR but being that I cant see that I'm afraid to add the 3.6, though I can't wait to
  8. #8 Re: Knock sensors not reporting??
    Nov 2013
    Des Moines, IA
    Have you ever measured KR or been able to ?
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  9. #9 Re: Knock sensors not reporting??
    May 2013
    I figured it could be the scanner so in installed some plug-ins and still nothing.. with the strange tune, is it possible that the were told not to report and shouldn't I get a CEL for knocks if malfunctioning?
  10. #10 Re: Knock sensors not reporting??
    May 2013
    I got 0.0 on one PID once and since then no data has been received
  11. #11 Re: Knock sensors not reporting??
    Nov 2013
    Des Moines, IA
    as stated ^^ any sensor failure will almost always throw a CEL.... but I have never heard or seen of someone "disabling" knock sensors might wanna try an aeroforce/or equivalent... maybe the app/bluetooth combo isn't reading the data properly
    2007GPGTSC
    " sad thing is "
  12. #12 Re: Knock sensors not reporting??
    May 2013
    I don't have the money for a 150.00 unit to scan. everything else is reading quickly, and reporting fine so why would this one sensor not read?
  13. #13 Re: Knock sensors not reporting??
    May 2013
    I don't mind waiting to put the new snout on but I have to do my coupler soon and if I have to take the snout off I might as well put the new snout with the 3.6, but only if I can scan for kr
  14. #14 Re: Knock sensors not reporting??
    Nov 2013
    Des Moines, IA
    Maybe its the configuration of the app. You have downloaded all the PIDS and plug-ins required. look around a bit on google there are different configs out there for different applications. honestly I haven't used one before but from the sounds of it if the wires, and sensors are intact with no CEL's I would think the config on the app. but thats just me
    2007GPGTSC
    " sad thing is "
  15. #15 Re: Knock sensors not reporting??
    your using the torque app? if so theres a thread on how to get it to read KR.
  16. #16 Re: Knock sensors not reporting??
    May 2013
    I've downloaded all of the GM specific PIDs and the Grand prix PIDs as well, i have 3 different knock retard PIDs and none report
    I downloaded the knock detector but i think its a dummy test, it counts the timing retard from the pcm as well as load and throttle pos.
  17. #17 Re: Knock sensors not reporting??
    May 2013
    i looked at all of the torque app threads and I believe I have it set correctly
  18. #18 Re: Knock sensors not reporting??
    The Boss Iceman6669's Avatar
    Jun 2011
    I did that to mine when I thought my knock sensors crapped out and I got nothing. Mine later started blipping when the weather changed.
    2011 F-150 Yote powered
  19. #19 Re: Knock sensors not reporting??
    May 2013
    colder or hotter?
  20. #20 Re: Knock sensors not reporting??
    May 2013
    I'll find me a 3/4IN wrench and giver a lil smack around and see what happens. Any ideas if it will register if i just smack the exhaust manifold? I'd rather hit there because the knock sensor is right near there.
  1. are there 2 knock sensors on a 97 gtp ?
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2013, 08:39 PM
  2. Knock sensors
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-11-2012, 08:06 AM
  3. Knock sensors...
    By JKICK6 in forum General Tech Discussion
    Last Post: 09-25-2012, 11:07 PM
  4. phantom KR without knock sensors
    By 97gpl36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2011, 04:57 PM
  5. Knock Sensors Location 3800
    By MDThomas26 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2010, 12:23 PM
