Thread: 97 gtp no start!!
Results 1 to 16 of 16
  1. #1 97 gtp no start!!
    Nov 2013
    Boulder Hill, Illinois
    Hi guys new here but I'm having problems with my GTP.
    Ok here's the info on my car and problem I'm having.
    97 GTP. Mods are as follows: intake, smaller pulley, throttle body spacer, and zzp tuned.
    So recently my car had been having a rough idle so I decided to clean the throttle body(done it many times on my supercharged cobalt and helped alot). So I get it all clean up(it was extremely dirty), new gasket installed hook everything back up, go to start it and no start. Car cranks but won't start! Codes I'm getting are p0122- tps sensor bad- new sensor installed but no luck, im also getting a cylinder six misfire. Any suggestions as to what it could be? Thanks
  2. #2 Re: 97 gtp no start!!
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    loose connection to throttle pos sen?
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  3. #3 Re: 97 gtp no start!!
    Nov 2013
    I have checked and it doesn't seem to be loose, I'll check over it again. Anything else it could be?
  4. #4 Re: 97 gtp no start!!
    Cyl 6 has to be old because if you aren't starting..you can't misfire.
    The TPS is likely the cause. And since you tried a new sensor, it's likley the wiring going to it. Try testing the ground and voltage at the connector with key on. They sell new pigtails.
  5. #5 Re: 97 gtp no start!!
    May 2013
    any backfiring noises or anything, - describe the sounds while turning over, you may need cables or charge up the battery
  6. #6 Re: 97 gtp no start!!
    Quote Originally Posted by ntreftz View Post
    Pssst.. you know Scottydoggs is likely right.
  7. #7 Re: 97 gtp no start!!
    Nov 2013
    Ok I'm going to check again. I might just buy a new pigtail. Slight "pop" noise from exhaust after cranking it.
  8. #8 Re: 97 gtp no start!!
    May 2013
    right about what?
  9. #9 Re: 97 gtp no start!!
    Pull the tb spacer out and insure you don't have a vacuum leak at the tb
  10. #10 Re: 97 gtp no start!!
    May 2013
    any luck
  11. #11 Re: 97 gtp no start!!
    Nov 2013
    No luck. Noob question, but is there any tps re learn for these cars?? Thanks
  12. #12 Re: 97 gtp no start!!
    Nov 2013
    Anybody?? Thanks
  13. #13 Re: 97 gtp no start!!
    No there isn't.
    Have you determined which is missing.. spark or fuel ?
  14. #14 Re: 97 gtp no start!!
    right about what?
    The TPS is likely the cause. And since you tried a new sensor, it's likely the wiring going to it. Try testing the ground and voltage at the connector with key on. They sell new pigtails.
    im always saying to check the pig tail wires.
    any chance you sprayed the maf with what ever you cleaned the TB with? that can kill the maf fast. only maf cleaner should be used on the maf.
  15. #15 Re: 97 gtp no start!!
    Nov 2013
    Sorry for the delayed updates.
    No luck yet! Now I've bought the new tps, new pigtail(small tear on it). I removed the MAF to clean it with MAF cleaner, but is there any chance a bad MAF could cause it not to start? Thanks. Again car turns over and since changing the tps I'm getting a loud backfire
  16. #16 Re: 97 gtp no start!!
    Unplug the maf and try to start it.
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. what to start getting for my 07 GXP
    By rockbassray in forum General Tech Discussion
    Last Post: 10-16-2012, 05:11 PM
  3. TC off at start....is it possible?
    By asite57 in forum General Tech Discussion
    Last Post: 06-15-2012, 10:13 AM
  4. 98 GP Won't Start
    By Fuzzydragon88 in forum Introductions/Noob Questions
    Last Post: 04-05-2012, 02:08 PM
  5. Rev's at start up
    By 2003GPGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2010, 06:58 PM
