Thread: Car won't stay running
Results 1 to 10 of 10
  1. #1 Car won't stay running
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Car seems to not want to stay running. I have a few problems that I'm unsure of.
    1. Pushing the brake does not disengage the locking mechanism to let me shift out of park.
    2. Key will not come out of ignition so I taped up that brass button thing on the white clip mechanism.
    3. Car won't stay running for some reason.
    http://s1334.photobucket.com/user/th...in=true&page=1
    Go there for a video of the car dieing. Even when it starts to die out and I push the gas it just seems to make its death all the more painful. By that I mean when it starts dieing out, I push the gas and it just shakes harder as it stalls the rest of the way out.
    Changes already done to the car:
    Plugs and wires, plugs a few times since I had an issue running lean but fixed that with a new boost bypass solenoid.
    New 195° thermostat yesterday.
    ZZP catted downpipe.
  2. #2 Re: Car won't stay running
    That's either fuel or fuel related.
    What year is this? If it's 97-03 find the fuel pump resistor fix (bending the tab on the fuel pump speed relay.) Cam.. I can't find any of the posts with the pic. Please add.
  3. #3 Re: Car won't stay running
    Aug 2011
    Michigan
    Yeah its a 99.
    You can't find the pics/video in that link?
  4. #4 Re: Car won't stay running
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  5. #5 Re: Car won't stay running
    Aug 2011
    Michigan
    Thanks for the info! I'll look into it more after my classes for the day. Also, can anyone see the video I posted on PhotoBucket?
  6. #6 Re: Car won't stay running
    Aug 2011
    Michigan
    So been idling for about 40 minutes now without a problem. What the crap o.O
  7. #7 Re: Car won't stay running
    The resistor can do this type of thing. So can as well. I'm all about trying free first though. The resistor will typically fail all of a sudden, but it's possible to have an intermittent as well.
  8. #8 Re: Car won't stay running
    Aug 2011
    Michigan
    Where is this resistor? I looked in my relays or whatever and it looked like the pic here, but without the tab thing
    http://www.grandprixforums.net/showt...uel+pump+relay
  9. #9 Re: Car won't stay running
    Aug 2011
    Michigan
    Replaced the blown BTSI fuse in the glovebox and can now get key out of ignition without any issue. But still have to have my shifter rigged up so I can shift without pushing the override button next to the shifter. So 1 problem solved!
  10. #10 Re: Car won't stay running
    Aug 2011
    Michigan
    Car hasn't stalled in a bit, but the dashboard lights like the boost screen and the outside temp screen and what not keep flickering. Then they will stay on and lit up, then flicker again. Not sure where to start with this one
  1. l67 engine wont stay running..got the car running. tons of white smoke from exhast
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 05:14 PM
  2. car won't stay running
    By nawarkk in forum General Tech Discussion
    Last Post: 12-18-2012, 11:21 AM
  3. Car won't stay running...
    By 2000GTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-26-2010, 06:43 PM
  4. Car wont stay running *HELP!!!
    By silverPGP in forum General Tech Discussion
    Last Post: 06-06-2010, 02:46 PM
  5. Car will not stay running
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 07:30 AM
