Thread: weird s/c noise
Results 1 to 20 of 25
  1. #1 weird s/c noise
    SE Level Member Orange04CompG's Avatar
    Aug 2013
    Austin,Texas
    so i have a 04 comp g and whenever i push the pedal about 1/2 way down and get to about 3k rpms and the boost gauge is about half way up, the s/c makes a weird variation of its normal whine. its like if youre standing on something thats vibrating hard and you say something your voice sounds kind of shaken up, thats what it sounds like. its really hard to describe. ill try to get a video up in a bit. also when it makes the noise you can feel the car holding back. any ideas what this may be? im stumped.
  2. #2 Re: weird s/c noise
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    Worn coupler or needle bearings?
  3. #3 Re: weird s/c noise
    Aug 2013
    Austin,Texas
    heres a link to the videos. im in a neighborhood so i couldnt go to fast for to long or else my neighbors wouldve gotten mad. you have to listen closely though cause i had to use my phone and my keys were bouncing against the plastic
    http://www.youtube.com/watch?v=-Rxg1...ature=youtu.be
    http://www.youtube.com/watch?v=a1LKl...ature=youtu.be
  4. #4 Re: weird s/c noise
    Aug 2013
    Austin,Texas
    and i dont think it would be the coupler because if it were, wouldnt it make the noise at idle too? mine only makes it at higher boost psi and its more of a strange variation of the whine than a rattle that would be caused by the bad coupler
  5. #5 Re: weird s/c noise
    Dec 2012
    Where 4T65E's were born
    There was a post just like this a few months ago, it was basically a shuddering. I'll try to find it but I can't guarantee it with the search.
    Sold.
  6. #6 Re: weird s/c noise
    Aug 2013
    Austin,Texas
    yeah a shuddering type sound! thats exactly what it is
  7. #7 Re: weird s/c noise
    Dec 2012
    The post I failed to find had a video too. He'd floor it, it would accelerate fine until like 3,700 rpm, shudder to 4,500 then accelerate perfect to 5,800 and shift.
    Sold.
  8. #8 Re: weird s/c noise
    I live here. TLSheff's Avatar
    Shuddering could be several things, just out of curiousity when was the last time you did a tune up? and how many miles does your car have?
  9. #9 Re: weird s/c noise
    id say its tune up time. how long since the last one? what plugs did you use when you changed them?
  10. #10 Re: weird s/c noise
    Aug 2013
    Austin,Texas
    i just changed my plugs like a month and a half ago and its ran great until a couple days ago. the shudder isnt from the engine, its from the s/c. if you watch the videos you can hear it. the car has 138k but most are highway miles
  11. #11 Re: weird s/c noise
    Aug 2013
    Austin,Texas
    and mine runs fine until about 3500rpm and then the shudder doesnt go away until i take my foot off the gas
  12. #12 Re: weird s/c noise
    Feb 2013
    37.295091, -121.930053
    sometimes a bad harmonic balancer can cause a rumble in the engine or a bad engine mount. had that happen on a 1973 camaro the motor mounts were the wrong ones. you would end up with a vibration in car at any rpm. but that my 0.02
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  13. #13 Re: weird s/c noise
    Quote Originally Posted by Orange04CompG View Post
    thats totally your engine shuddering, its just that you can hear the engine via the sc as it shudders. and thats what car with misfires sounds like btw.
    what plugs did you put in?
  14. #14 Re: weird s/c noise
    Aug 2013
    Austin,Texas
    iridium tipped ac delco plugs
  15. #15 Re: weird s/c noise
    Aug 2013
    Austin,Texas
    so what should i start with looking in to?
  16. #16 Re: weird s/c noise
    pull the plugs, check them out. check the wires to see they are not stuck to the exhaust manifolds or something like that. or a cracked coil.
  17. #17 Re: weird s/c noise
    Aug 2013
    Austin,Texas
    my coils and wires are good. ill pull the plugs tomorrow. anything else i should check?
  18. #18 Re: weird s/c noise
    It is an 04 model... with the craptastic LIM gaskets... are you low on coolant?
  19. #19 Re: weird s/c noise
    Aug 2013
    Austin,Texas
    Nope. All my fluids are good. This morning it got worse though. It's definitely the engine shuddering. You can feel it through the gas pedal when you step on it. I'm going to replace my engine mounts with the poly ones from zzp and check my plugs and if that doesn't fix it I'm taking it somewhere to get it looked at. I love my car with a passion but these repair bills are killing me lol
  20. #20 Re: weird s/c noise
    Sep 2011
    Copperas Cove, TEXAS
    Any codes? Mine did this 2 weeks ago, it ended up being a bad MAP and IAC. Also cleaning the MAF helped.
  1. Weird noise
    By mthorn11 in forum Engine
    Last Post: 06-24-2013, 08:42 PM
  2. Weird noise!
    By ajoliver2010 in forum Brakes/Suspension/Chassis
    Last Post: 05-31-2013, 01:53 PM
  3. Help weird noise
    By macey43 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-10-2011, 09:56 AM
  4. Weird Noise help!!!
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 12:31 PM
  5. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
