Thread: Coil Pack Issue/Question...
Results 1 to 10 of 10
  1. #1 Coil Pack Issue/Question...
    SE Level Member Primal's Avatar
    Aug 2013
    Old Saybrook, CT
    Hey All!
    So, I'm doing plugs and wires here as I wrap up the LIM Gasket job and I see that terminal 5 is all rusted and 2 doesn't look as shiny as the terminals on the other packs. I was going to just Scotch-Brite the terminal and reassemble, but I'm wondering now if there's an issue with this coil pack. It looks possibly dead to me.
    I have the plugs below also. The plug from #5 definitely doesn't look as dark as the others. It's fired for sure, but it's not like the others. I have 2 and 6 pictured for comparison.
    Do I need to replace the 2/5 coil pack, all the coils or what?
    Thanks!
    Here's Plug #5
    Here's #2
    Here's #6
  2. #2 Re: Coil Pack Issue/Question...
    Feb 2013
    37.295091, -121.930053
    Well you can just replace the 1 pack with the oem replacement if you like but since your not saying anything about codes then its really up to you.
    Dam phone
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Coil Pack Issue/Question...
    Aug 2013
    Old Saybrook, CT
    Yeah, I was going to mention that, to my knowledge, there were no codes. This is my mom's old car. She owned it since new. She got a new car and I "inherited" this one. As far as I know, there were no codes in the info center. I don't have a scan tool though, so I have no idea what that would say.
    Adam
  4. #4 Re: Coil Pack Issue/Question...
    Feb 2013
    Well to be safe change it.
  5. #5 Re: Coil Pack Issue/Question...
    I'd just clean them up and use some di-electric grease so water can't get to them again.
    I don't see a huge problems with the plugs, they kinda just look worn out to me.
  6. #6 Re: Coil Pack Issue/Question...
    Aug 2013
    Old Saybrook, CT
    OK, so I guess I'll just clean them up and run it to see what happens. I'll probably change them later, but it's not like I have to do it now or repeat a lot of work. They're on top :-P
    Thanks, guys!
    Adam
  7. #7 Re: Coil Pack Issue/Question...
    plug 5 looks like it never fired. almost new, id clean the coil tips up with steel wool, grease them all and see how it runs with new wires and plugs.
  8. #8 Re: Coil Pack Issue/Question...
    Aug 2013
    Old Saybrook, CT
    Thanks, man. That's where I'll start before I start replacing stuff at least.
    Adam
  9. #9 Re: Coil Pack Issue/Question...
    Definately how us CT guys roll.
    I've cleaned many and they seem fine after.
  10. #10 Re: Coil Pack Issue/Question...
    Aug 2013
    Old Saybrook, CT
    Thanks, Bill!
  1. coil pack
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 11-18-2012, 02:57 PM
  2. MSD blaster coil pack question
    By JoelW98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2012, 09:11 PM
  3. Coil pack question
    By Logan541 in forum General Tech Discussion
    Last Post: 12-31-2011, 08:45 PM
  4. coil pack
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-13-2010, 12:22 AM
