Thread: Brake won't disengage
Results 1 to 8 of 8
  1. #1 Brake won't disengage
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    So my car, ever since I bought it did this cool little thing where it randomly wouldn't disengage. I undid the boot and the staple thing holding the shifter in place. Then I would pull the shifter knob up and down until finally it would allow it to disengage and I could then shift it out of park.
    Today, however, I went to park the car on a slant to go to class and it wouldn't allow the key to turn backwards enough for me to pull it out. So I went to move the car and it wouldn't disengage the brake at all. I now have to push down the button beside the shifter with a pen for it to shift. And the key still won't unlock for me to pull it out. Any advice?
  2. #2 Re: Brake won't disengage
    Under the steering wheel is a small cover, pop that out with a small screw driver and stick it up in there and it will push in a thingy and let the key come out.
  3. #3 Re: Brake won't disengage
    Aug 2011
    Michigan
    Lol alright. I will look for the small thingy to press once I get back out to the car. Thank you! But what do I need to do to fix it so this issue doesn't happen again and so that my car will shift out of park without having to push in the button next to the shifter? =/
  4. #4 Re: Brake won't disengage
    Aug 2011
    Michigan
    Found the thing I have to push. But I have to do it every time I want to pull the key out now =/
  5. #5 Re: Brake won't disengage
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    Ziptie the button down! thats what I and others have done
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  6. #6 Re: Brake won't disengage
    GTP Level Member buickman104's Avatar
    NYC
    You can also get a piece of hose cut it open and jam it between the button and the plastic cover. That will also keep the button depressed.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  7. #7 Re: Brake won't disengage
    Quote Originally Posted by buickman104 View Post
    Psst that's a copywritten move. You owe me $5 per time you say that.
    Open the console and look for a cut wire. Crbquist had this issue and recently posted in a thread about someone else having the issue. I mention him because he isn't a post whore like some of us and you'll be able to find the thread
  8. #8 Re: Brake won't disengage
    Aug 2011
    'Merica
    I did this on my GP too. I just pressed the button every time. You can tilt the column up and reach over the plastic to get to the button too.
  1. Replies: 2
    Last Post: 07-20-2013, 08:25 AM
  2. A/C compressor cluth wll not disengage.
    By Bluedogge in forum General Tech Discussion
    Last Post: 06-17-2012, 09:24 PM
  3. Starter motor wont disengage when engine is running 97 Grand Prix
    By Jacob Sexton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-29-2012, 02:59 PM
  4. brake parts to get for brake upgrade??
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:59 PM
