Thread: bog down while accelerating
Results 1 to 15 of 15
  1. #1 bog down while accelerating
    Mar 2012
    Hoffman Estates
    Hey guys! Once again a weird intermittent problem with my gtp...it looses power when driving randomly the engine will begin to bog down making the gas pedal harder to press and the engine will get louder than normal. I've changed quite alot in the last couple months but I can't seem to figure this out. I did FPR,LIM,UIM SUPERGASKET,WATER PUMP,FUEL FILTER,OIL CHANGE as of yesterday. Thought the oil change would help it definitely runs smoother.but I'm still having the.issue randomly.
    oh and another thing when the car starts to bog I usually just let off the pedal fpr a few seconds then it gets better after that
    Like i said intermittent
  2. #2 Re: bog down while accelerating
    Mar 2012
    Hoffman Estates
    I did read something about there being a primary fuel filter in the pump that needs to get changed? Is this true? If so I bet there's a write up for it!
  3. #3 Re: bog down while accelerating
    Try plugs and wires
  4. #4 Re: bog down while accelerating
    Mar 2012
    Hoffman Estates
    Plugs was my next step but I'm still leaning on that whole filter.in the pump? Anyone heard anything like that before?
  5. #5 Re: bog down while accelerating
    theres a sock on the end of the f/p, not a filter really. there is a inline filter tho.
    does the check engine light ever flash?
    id start with a tune up, then maybe if it still acting up the cat could be clogged or broken up inside blocking the exhaust.
  6. #6 Re: bog down while accelerating
    Mar 2012
    Hoffman Estates
    I have no cat I have zzp dp with o2 bung. And I changed the.inline filter on the bottom of the car couple months back
  7. #7 Re: bog down while accelerating
    Mar 2012
    Hoffman Estates
    Since my lim and uim yadda yadda no cels and no it doesn't flash or that'd b a sure heads up of bad plugs! Ty tho
  8. #8 Re: bog down while accelerating
    do the plugs and wires then, you'd be surprised what old plugs and wires can do. make it feel fine around town, get on it and it stumbles/bucks and has no power, let off and it goes again.
  9. #9 Re: bog down while accelerating
    Mar 2012
    Hoffman Estates
    That's exactly what its doing! After all the work she's been running beautifully this is the only bad thing about her right now! Ill give it a shot today and we will see what happens after!
  10. #10 Re: bog down while accelerating
    she goes under the knife again, well a little bit anyways lolmake sure you have a spark plug socket, one with a foam insert, this helps the plugs from breaking.
  11. #11 Re: bog down while accelerating
    WOuld help if we knew what you're driving
  12. #12 Re: bog down while accelerating
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    he said gtp in his first post.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  13. #13 Re: bog down while accelerating
    Mar 2012
    Hoffman Estates
    Yeah my bad! 2000 gtp 3.8 sc 234k miles )
  14. #14 Re: bog down while accelerating
    Gtp's were made for a wide number of years with quite a few changes throughout
  15. #15 Re: bog down while accelerating
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Torque converter maybeh?
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180ยบ Thermostat, Flipped Dog Bones
  1. bad vibration while accelerating help please!!!
    By 01RedfireGT in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:54 PM
  2. Vibration while accelerating
    By erichanson2009 in forum General Tech Discussion
    Last Post: 03-01-2012, 12:08 AM
  3. Stuttering when accelerating
    By bigwillie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-11-2011, 08:59 PM
  4. Trouble with Accelerating
    By miker4792 in forum General Tech Discussion
    Last Post: 05-01-2011, 07:11 PM
  5. Miss While Accelerating
    By TDilley in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2011, 11:52 PM
