First off, I just wanted to say that I appreciate the help I have received in the past from you folks. I have a new problem with my GTP.
2000 GTP S/C Series II
I had a problem previously with my fuel system and replaced the fuel pump, which did not fix it. I bent the connector over on the fuel pump relay and found the problem was the fuel pump speed resistor. I replaced the resistor and all was well for a few weeks. The car wouldn't start the other day and had to bend the connector over again indicating the resistor was bad, already. I haven't had the opportunity to pick up another yet and had another issue. The car wouldn't start again. I pulled both fuel pump relays and then replaced them after a minute or so and the car started right up. It did run pretty roughly (idling) for a short time then drove fine. The car has never died once it has started. It seems that it is on start-up that this issue occurs. I have turned the connector back so it runs through the resistor and it will still start and run fine, sometimes.
Any Ideas on what might be causing this besides a bad fuel pump or resistor?
