Im at a lose here...
Relevant: GenV, IC (front PCV blocked), and a new PCV...
Currently, I have the rear PCV running via vac line from the rear nipple to the TB (post maf, pre blade) and have the front coming from the oil fill cap to the same spot on the TB. The other day going WOT I get the burning oil smell and pull over to see oil everywhere and the dipstick out. I replace the PCV and as of tonight it seemed to have little to no affect on the problem. This is only happening during WOT and is otherwise fine.
Only thing Im thinking of now is blow-by? if thats the case, should I go back to the breather or is there something else I could look at?
-Jarred
