Thread: stock cam and 105lbs springs
Results 1 to 17 of 17
  1. #1 stock cam and 105lbs springs
    Jan 2013
    Australia
    hey people,
    i will be upgrading to 105lbs springs (+retainers etc.) and 1.95 Yella Terra roller rockers soon. I'm wondering whether the increased spring pressure will be ok for the standard camshaft to handle (i,e its hopefully won't cause it to snap lol)... and what about the stock lifters?
    Cheers
  2. #2 Re: stock cam and 105lbs springs
    Jan 2009
    Tallahassee, FL
    You won't have any problems. You may want to upgrade to a double roller timing chain though.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: stock cam and 105lbs springs
    GTX Level Member crbquist's Avatar
    Massachusetts
    Quote Originally Posted by Sandman View Post
    You don't need a double roller for 105's and rockers... Before my cam swap, I ran 105's with 1.9 rockers on my original timing chain/dampener for 30k miles with no problems. My cam swap was done at 105k miles, in which a new stock chain and dampener were installed. The factory chain/dampener appeared to be in excellent shape upon removal.
    OP: Your stock cam will be more than fine...
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  4. #4 Re: stock cam and 105lbs springs
    Jan 2013
    Australia
    cheers guys, forgot to mention that I will be upgrading to double row chain aswell
  5. #5 Re: stock cam and 105lbs springs
    Feb 2009
    flintnasty MI
    1.9 modded rockers would be a much better option than the rollers in my experience they have made 15whp more.
  6. #6 Re: stock cam and 105lbs springs
    Jan 2013
    Australia
    15whp more than rollers? So ~ +30whp more than stock rockers, cos rollers already give a 15whp gain...
    Yea I've been thinking about that... here in Australia we have 1.98 modded rockers.... but I've been told they are not reliable and the bearings in them are ****.
  7. #7 Re: stock cam and 105lbs springs
    Feb 2009
    flintnasty MI
    Rollers have never shown very consistant gains as claimed by shops that sell them in my experience.
  8. #8 Re: stock cam and 105lbs springs
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    No need to run a double roller its just a waste just a good condition single roller is fine
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  9. #9 Re: stock cam and 105lbs springs
    Jan 2013
    Australia
    Im going DR just to be safe... there have been people here who have had tensioners disintegrate with 105lbs springs... which blocked the oil feed and there go the bearings...
    But what i dont understand is why everyone always says that you NEED to upgrade springs when using 1.9 roller rockers... but modded 1.9's can get away with stock springs. This doesnt really fit in with the theory that modded rockers make more lift at a given ratio compared to rollers... or am i missing something here?
  10. #10 Re: stock cam and 105lbs springs
    Slower, Lower Delaware
    If you are I've been missing it too. No harm meant but this modded/roller rocker fight has convinced me of nothing.
    Quote Originally Posted by Schwuppes View Post
  11. #11 Re: stock cam and 105lbs springs
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Ive got 105 springs and 1.9 YT's also, no problems,on stock chain.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  12. #12 Re: stock cam and 105lbs springs
    I hope so. That's what I have.
    Quote Originally Posted by goldgp View Post
  13. #13 Re: stock cam and 105lbs springs
    Jan 2013
    Australia
    quick update...
    does the situation change with 130lbs springs?
  14. #14 Re: stock cam and 105lbs springs
    Jan 2009
    Tallahassee, FL
    Yes, but why that stiff on a stock cam/rockers? There's no reason.
    77 Morris Garage B
  15. #15 Re: stock cam and 105lbs springs
    Jan 2013
    Australia
    yea i know.... the guy from my performance shop said just put 130lbs... maybe he's expecting me to upgrade to a cam later on lol
    But yea... not sure if 130lbs springs on stock cam and lifters is a good idea either...
  16. #16 Re: stock cam and 105lbs springs
    I agree with you guys on the 1.9 modded vs roller and spring question. Although some roller rockers are heavier than stock, that could be a good reason.
    The weak point of the system isn't the cam or the lifters, it's the chain. Since you are going double roller, you should be fine with the 130#
  17. #17 Re: stock cam and 105lbs springs
    Jan 2013
    Australia
    cheers guys,
    Yea I asked him to put 105 lbs springs now... if i ever put a cam in it will only be a VS or XP at the most... and 105s should be fine for those small to medium size cams.
  1. Replies: 39
    Last Post: 02-04-2013, 10:42 AM
  2. stock or #105 springs
    By turbo6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 09:11 PM
  3. 1.9's and stock springs
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-28-2008, 05:08 AM
