Thread: lim uim redone but coolant leaking
Results 1 to 9 of 9
  1. #1 lim uim redone but coolant leaking
    Mar 2012
    Hoffman Estates
    2000 Pontiac grand prix gtp
    Put new lower and upper Intake manifold gaskets and supercharger gasket put new aluminum coolant elbows on too. After disassembley and reassembly going without problems
    stsrt the car up and its pissing coolant from somewhere just can see it!!!
    anybody else have this problem with gtps? Any gasket that could be leaking that I might have missed?
  2. #2 Re: lim uim redone but coolant leaking
    Banned
    Oct 2013
    Moorhead, MN
    Pissing coolant from "somewhere"..
    Really? You can't even elaborate as to where it's hitting the ground?
  3. #3 Re: lim uim redone but coolant leaking
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    did the supercharger gasket kit come with O-rings for the coolant passage in the s/c?
    When I changed my lim, it leaked at rad spring clamps. 10 year old spring clamps get weak. You may want to put a cooling system pressure tester on it to help isolate the leak before taking anything apart.
  4. #4 Re: lim uim redone but coolant leaking
    Mar 2012
    Hoffman Estates
    Its closer to the water pump or tensioner kinda
  5. #5 Re: lim uim redone but coolant leaking
    Ohio
    You probably didn't get the elbows in there all the way. Take it apart and make sure the holes are cleaned out.
    When you put it back together, let it work itself in, do not force it...
    But I guess that's what she said
  6. #6 Re: lim uim redone but coolant leaking
    Banned
    Oct 2013
    Moorhead, MN
    Probably a tensioner elbow. Plastic? If so. Buy the aluminum.
    A front cover bolt could have come loose or fallen out. I know a few of them go into the water jacket.
    Is your water pump new? The bearing could be going out and leaking from the weep hole. Also, a few of the pump bolts go into the water jacket.
    Or your radiator hose.
    Or a bad gasket, of course.
    I believe that's all for that side of the engine.
    When I rebuilt mine, I had 2 massive leaks (like you described). Turned out I forgot 2 of the front cover bolts.
    Look up my thread "Coolant Leak", I've got dealership schematics and pictures.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  7. #7 Re: lim uim redone but coolant leaking
    Mar 2012
    Hoffman Estates
    Got it earlier it was the water pump pissing out coolant everything is all back together and she's running like a champp
  8. #8 Re: lim uim redone but coolant leaking
    Mar 2012
    Hoffman Estates
    Oh and btw Changing that water pump ain't easy that's fashoo
  9. #9 Re: lim uim redone but coolant leaking
    Remove a belt or two
    Lower a power steering pump 2 x 13mm bolts
    Remove 4 10mm bolts
    Remove 4 13mm bolts
    Clean gasket surface and reinstall
    The expected labor time on this job is about an hour. What gave you a hard time?
  1. leaking coolant help
    By 02grandprixgtp in forum General Grand Prix Discussion
    Last Post: 12-20-2012, 04:38 PM
  2. Coolant Leaking Bad!
    By Ralphie in forum General Tech Discussion
    Last Post: 02-12-2011, 03:07 PM
  3. Leaking Coolant
    By nav in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-20-2010, 04:04 PM
  4. Think im leaking coolant
    By blackgpgt in forum General Tech Discussion
    Last Post: 02-14-2010, 03:56 PM
  5. Leaking coolant.
    By c002529 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-16-2010, 12:21 PM
